Budget (including currency):  R 30 000
Country: South Africa
Games, programs or workloads that it will be used for: Mostly Gaming and Streaming
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): Upgrading from an Xbox one S. I just wanna be able to play modern day games at high quality. My aim is to get PS5, XBOX series X and better level. I will be doing this in steps eg. Motherboard first then CPU etc.
https://linustechtips.com/topic/1354921-first-gaming-build-help-needed/
hard to compete with PS5/XBOX ONE performance with your budget, due to the insane GPU prices at the moment.
My advice: wait for prices to drop, before building a new machine with no old GPU to use.
Quote or tag me( @SEAL62 ) if you want me to see your reply
consider a reaction if I was funny, informative, helpful, or agreeable
OS: Windows 10 Pro
CPU: Intel i9-9900K GPU: Aorus GeForce RTX 3080 Master Motherboard: Gigabyte Z390 Aorus Master
AIO: Corsair H150i RGB Platinum RAM: Corsair Vengeance RGB Pro 32GB 3000MHz Case: Corsair iCUE 465X RGB PSU: Corsair RM750x White
OS: Kali Linux
HP Envy x360 Convertible
CPU: Intel i5-10210U GPU: NVIDIA GeForce MX250 RAM: 16 GB DDR4 2666 SSD: 512GB PCIe
Understood. I don't mind getting the rest in place so long. Motherboard CPU Ram.
AMD is a good choice for CPU at the moment, Ryzen 5 or higher should do the trick with competing performance to PS5 levels. Gigabyte or more specific AORUS is my choice for mainboards. RAM doesn't really matter, anything over 3000 MHz and 16 GB or more should be perfectly fine for any latest or last gen Ryzen CPU.
OS: Windows 10 Pro
OS: Kali Linux
Thanks so much Seal62. I've heard very good things about AMD lately.
