I have always not been comfortable having a rad in the front intake. To me it just seems to preheat the air coming into the case. If there are any other rads serving as exhaust, then they don't get fresh ambient air going through them. Instead they get case air that is already preheated from the front rad. Plus this preheated air serves to make other components on the motherboard hotter like the VRM's or capacitors. I thought and thought about a solution to avoid this preheated front intake air and what I came up with is the configuration below.
This way no exhaust from anywhere is poured into the case only exhaust out the top and back with copious amount of fresh air coming in through the unobstructed front fans. This should make the air inside the case basically the same as ambient. Ergo then the top and rear exhaust rads get fresh ambient air passing through them.
However, I have not been able to find a single case with good air flow that has both 360 top and rear rad capability.
So, is my thinking correct about avoiding front rad preheated air coming into the case and is this a good solution to that, or am I making an issue out of a nonissue?
Thank you
https://linustechtips.com/topic/1354461-optimal-air-flow-cooling/
How on earth will a case have rear rad capabilities?
Front rads are fine, and yes they do preheat the air but that means the CPU gets cooler air than the GPU.  Which is what some want.
You're making an issue out of a non-issue.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose, Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
yeah that.
it's a computer not a sky scrapper. the air doesn't sit in the machine long enough to make a difference where the rad is.
Note that most every car on earth is blowing hot air directly from the rad onto the engine and they all work just fine. You;re cooling the machine with water not air , wouldn;t even matter if the air in the case was hot anyway as long as the water is cold.
3 minutes ago, emosun said:
yeah that.
Yea, I agree it is mostly a nonissue. But would the configuration I posted (if a 360 rear rad was possible) in a good air flow case, then would it make even 1 degree cooler temps? Why not let us aim for optimal, even if it wont matter much.
5 minutes ago, Jeppes said:
Do you really need 2x360?
I think at least Phanteks Enthoo pro2 fits those as exhaust in roof, side or bottom.
Absolutely not lol. A GPU with good air cooling and a NH-D15 will work fine. But why not explore new possibilities?
no probably not.
what you aren't factoring in , is all you've done is take the now hot exhaust air the computer produces and are now blowing it through the radiator. So no , your solution wouldn;t really gain anything and might actually be worse.
You want a perfect setup? put the rad entirely outside of the case. cool air goes in , hot air is outside the case. the perfect place for your cars radiator if all you cared about was cooling.... is straight up and down on the roof.
Should be pretty obvious, but there is no case with 360mm radiator support for the rear, because that's where the graphics card mounts to.
If you still want to try the concept yourself, simply turn the fans around. That'll cause a lot of dust to get into the case tho.
2 minutes ago, emosun said:
no probably not.
But that doesn't look cool.
so in taking cooler air will make w/e its contented to cooler but everything els hotter. putting he ran on top will intake hoter air and make w/e its connected to hotter compared to the front but wont heat up the vrm, gpu, mb pcbs. so its a trade off.
case that have that were designed around water cooling have a bottom rad mount and intake from the side bottom and out the side bottom.
but because of water cooling being so expensive they build most pc case around the 360 aio.
lian la has an bottom case cumming end of this year. and hopefully silver stone got SOMETHING...
10 minutes ago, Nanook said:
Unless manufacturers make the case really wide? It could happen.
its been done...
https://www.raijintek.com/en/products_detail.php?ProductID=124
i think there was an inwin 909 case as well that had a back mount but dont remember.
In Win 909 ATX Case Review - Page 3 of 4 - ExtremeRigs.net
inwin 982
inwin 925
Edited by thrasher_565
the lian li air could do in front in bottom out side and top
