Was thinking of using blue drives at 5400 rpm. So I guess it's safe, eh? Also, whats the limit degrees?
Don't know what the operating limit is, but CrystalDiskInfo shows the temp as yellow when they get up to 55.
Desktop: Intel Core i7-6700K, ASUS Z170-A, ASUS STRIX GTX 1080 Ti, 16GB DDR4 RAM, 512 GB Samsund 840 Pro, Seasonic X series 650W PSU, Fractal Design Define R4, 2x5TB HDD
Hypervisor 1: Intel Xeon E5-2630L, ASRock EPC612D8, 16GB DDR4 ECC RAM, Intel RT3WB080 8-port RAID controller plus expansion card, Norco RPC-4020 case, 20x2TB WD Red HDD
Other spare hypervisors: Dell Poweredge 2950, HP Proliant DL380 G5
Laptops: ThinkPads, lots of ThinkPads
OK, I've held back for too long.
So can anyone guess why drive bays are always the first to get hit with inlet air? Anyone ever see a drive bay situated near the back (hot area) of the air flow?
Sure, many have not had a hard drive overheat, but it does not mean they won't, especially as they get older (talking years on under a year). Look around all case designs and their selected drive bay location.
Think, think, think...
I roll with sigs off so I have no idea what you're advertising.
This is NOT the signature you are looking for.
Yeah I know that. But ever also think that they are more than one trays? Maybe only one mechancial HDD won't overheat, that's was the main purpose of this post...
Good luck, with that!
Surprise that no one has linked Google's study on it: http://static.googleusercontent.com/media/research.google.com/en//archive/disk_failures.pdf
AFR = Average Failure Rate
Having hot HDD apparently isn't a big issue.
15" MBP TB
AMD 5800X | Gigabyte Aorus Master | EVGA 2060 KO Ultra | Define 7 || Blade Server: Intel 3570k | GD65 | Corsair C70 | 13TB
Unless you have a 10K RPM or higher hard drive, most will be fine.
so what is a good temperature for a HDD. i use a laptop most of the time, it averages 35-40dC, but in summer when it gets 40+ dC, the HDD gets to 50-55 dC. its that bad for it ot not.
It's definitely not good. I like to play it on the safe side, so I would get a laptop cooler of some kind.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
