Motherboard 4 PIN CPU cable in 8 PIN
Solved by Alyxia,
According to the manual for that motherboard.
Should be fine if you plug it in correctly.
Just don't try to overclock any CPU, or try to pull more than 90w from a 2x2, or you might have a bad time.
They recommend 2x4 for 130w+.
Featured Topics
UnRaidLegends ·
Posted in Laptops and Pre-Built Systems0 -
2
7
2
Shane Martin ·
Posted in Displays2 -
5
INotPablo ·
Posted in CPUs, Motherboards, and Memory2 -
PatRed ·
Posted in New Builds and Planning8
