CPU :- Ryzen 5 Pro 4650G
Motherboard :- MSI A520M-A Pro
Ram:- Adata XPG 16 gigs 3000mhz
Storage:- Seagate 1 tb HDD at 7200rpm
Driver :- Latest Adrenaline software(problem occured on every version I had), Latest Windows version(same thing here).
Everything is at stock and Ram is running at XMP speeds
Problem :- Valorant(from Riot's site) starts, gets to the map loading screen and just gets stuck, nothing happens.
Warzone(from Battle.net), GTA V(from Epic games) and Mud Runner(from Epic games) all work perfectly.
Any idea what's causing this??
https://linustechtips.com/topic/1352491-valorant-wont-work/
Prob not an issue of those other "wrong" games
Maybe just w10 being buggy as usual or just a stupid driver issue
Id suggest running prime95 for 30 min (cpu)
furmark for 30 mins (gpu)
And memtest 5 loops (ram)
These will stress your hardware to see whether you have unstable hardware or just defective hardware
If any of them crash or error (memtest) then report it here
https://linustechtips.com/topic/1352491-valorant-wont-work/#findComment-14842591
Ok will do it asap 👍
https://linustechtips.com/topic/1352491-valorant-wont-work/#findComment-14842613
