PC Build Specs
5 minutes ago, bapoi555 said:Hello, I was going to build a PC for my friend and wanted to ask what you guys think of these specs. The budget is around 1100$, I am located in Switzerland.
Intel Core i5-9600KF
GTX 1660 Ti -or- RX 5600 XT (He doesn't need a top of the line GPU since he doesn't play GPU-intensive games)
Gigabyte Z390 UD (MoBo)
Crucial Ballistix (2x 8GB DDR4 3200mHz)
Adata SX8200 Pro (M.2 NVMe SSD)
Seagate BarraCuda (3 TB)
Seasonic Focus GX (650 W)
Arctic Liquid Freezer II 240
Phanteks Eclipse P400 Tempered Glass (Midi Tower)
Are these specs ok or would you have a better suggestion? Thank you for your help and have a great day!
get the i5-10600KF because it has more threads and higher clocks. also, it is based off of a newer architecture. i’d highly recommend it over the 9600kf for the reasons above. also, you could get by with an air cooler such as a arctic freezer esports duo lol or scythe fuma 2 and it should save some cash.
