Are we going to talk about the chunk in the corner that's just gone?
I would be more worried about the actual CPU socket underneath this.
Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy.  If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear.
https://linustechtips.com/topic/1350914-help/#findComment-14831200
Just change the Motherboard Entirely, Like wandering the Used market to find a Replacement. Because if the Socket are Fried are the Motherboard will just fine?, Also how did you got in there?. Did you do extreme overclocking or bad Power management in BIOS?, If you do... Just change the Motherboard, The socket it self can't be a Guarantee
Hello there... I'm both speedrunner and tech nerd. But not professional...
steam pcpartpicker.com speedrun.com
https://linustechtips.com/topic/1350914-help/#findComment-14831213
