gpu coreclock is low
By
Mando772004
in Graphics Cards
in Graphics Cards
Solved by Freakwise,
4 minutes ago, InfernalClaw said:it fluctuates
unless the fps doesnt drop much or you basically dont care about any of the change those little clock drop do..
then id say your gpu is perfectly fine
but if you want those 1950 clock back, then i guess you can use after burner and increase the power target
Playgb2 ·
Posted in Troubleshooting1 -
1
1
5
kasdashd ·
4
6
Ishikudeska ·
Posted in New Builds and Planning2
play_circle_filled
Latest From ShortCircuit:
