Can i write a linex mini kernel using python or at least rewrite one ???
3 minutes ago, ken00H said:Can you tell what kind of hardware???
I don't know specifically. The reason I made that comment is that when Java was the trendy language, it needed a specific runtime environment (the Java Virtual Machine) which was most often implemented in software - however, I believe there were a few chips that implemented a JVM in hardware instead, allowing you to run Java on the bare metal.
Theoretically, it might be possible to have a chip which can interpret Python bytecode in hardware in a similar way. I doubt any such thing actually exists, as it's not clear what the use for it would be, but even if you did, the end result would probably be a very long way from Linux.
As @trag1csays, you really need a language that compiles/assembles to machine code.
