980 pro issue
Go to solution Solved by Electronics Wizardy,
1 minute ago, Lave said:
the graphics card one?
if thats what you mean how am i supposed to tell if it works on it if i dont have a video output
Just return the 980 then and get a sata ssd then. Cheaper and just as fast here. That adapter is probably your issue, but when get a nvme drive for this use case.
I just purchased a 980 pro as part of me slowly upgrading my system my motherboard does not have an m.2 slot so I got a pci e 1x adapter a blue light comes on for the adapter when plugged in but no new storage device appears not in disk management or documents or even the bios any ideas?
Samsung software tools have an NVME driver but it does not support the 980 pro is this a situation where I will have to wait for till I buy a new mother board as the current one is a a320 or is it the ssd fault or drivers not supporting it?
https://linustechtips.com/topic/1350636-980-pro-issue/
Return the Pro, buy a SATA SSD and you won't know the difference.  Or do you do heavy video editing?
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1350636-980-pro-issue/#findComment-14828538
the adapter I'm using is the CERECO 1 x Nvme PCIe M.2 (NVME) M Key SSD to PCI-E X1 Adapter Card Support 2230 2242 2260 2280 ( 1PCS , Black )
the motherboard is the A320M-A PRO (MS-7C51)
Can you return it? Id just get a sata ssd.
Does the ssd work in the other pcie slot?
https://linustechtips.com/topic/1350636-980-pro-issue/#findComment-14828552
https://linustechtips.com/topic/1350636-980-pro-issue/#findComment-14828561
Either buy a motherboard that has a compatible M.2 Nvme slot or return the 980 pro for a standard sata SSD. It's really one or the other. An M.2 Sata SSD should work in that adapter, however it does need to be in a x16 or x8 pcie slot not a x1 or x4.  If you're just gaming or using it for storage, it's not going to make even the slightest difference in speeds. Unless you have a motherboard that has a PCIE Gen 4 M.2 slot getting a drive such as the 980 Pro is absolutely pointless. Getting an M.2 drive in a computer that doesn't even have M.2 support at all is even more so.
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - PNY Gaming OC RTX 5080 16GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S26 Ultra - Black 256GB |
https://linustechtips.com/topic/1350636-980-pro-issue/#findComment-14828573
I've had an NVMe SSD (The SN750) on my old Intel C600 chipset motherboard with a Xeon E5-1650 (first generation) CPU with a Sabrent NVMe to PCIe 16x adapter and it worked fine. Typically whether or not Windows recognizes it is down to the motherboard's support for PCIe storage, which you can actually check if your motherboard's BIOS allows you to see what devices you have connected. I don't see why this wouldn't be working. Also for all of you saying that a SATA SSD would be just as fast in this implementation, it's not??? Like I was able to get much faster speeds, maybe not full potential but still close to 85-90% performance, out of a Gen 3 PCIe slot on a motherboard from 2012?
My profile picure is real. That's what I look like in real life. I'm actually a blue and white African Wild Dog.
Ryzen 9 5900X - MSI Ventus 2x OC 3060 Ti - 2x8GB Corsair Vengeance LPX 3200MHz CL16 - ASRock B550 Phantom Gaming ITX/ax
EVGA CLC 280 + 2x140mm NF-A14 - Samsung 850 EVO 500GB + WD Black SN750 1TB - Windows 11/10 - EVGA Supernova G3 1000W
https://linustechtips.com/topic/1350636-980-pro-issue/#findComment-14828581
Wel speed wise, it might actually be slower than sata, as op is using a pcie gen 2 x1 slot, capable of about 500mB/s max. It should still show up in the os, but I think the adapter is the issue here.
https://linustechtips.com/topic/1350636-980-pro-issue/#findComment-14828609
PCIe 3.0 X16 vs PCIe 2.0 X1 is no comparison. Your SSD will no doubt get mad bandwidth.
Also this appears to be a gaming computer for the most part so a high end super fast NVMe SSD is superfluous either way.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1350636-980-pro-issue/#findComment-14828619
