I have a r7 5800x with 32gb of memory running at 3200mhz cl16 and i have a msi gaming x trio 3080 now i noticed im getting stutters in many games so i decided to borrow my friends 1080 Ti and voila no stutters so my 3080 is the problem for some reason so should i RMA it or is it fine? i mean im playing on 1080p ultra im getting good frames but the stutters are very obvious while on the 1080 ti there are no stutters. even many people benchmarking the same build dont get stutters using the 3080 but i do so should i rma it or maybe its just a game issue. it stutters in days gone watch dogs legion horizon zero dawn fortnite hitman and apparently all those games for other people with my build never stutter.
https://linustechtips.com/topic/1350340-need-help-on-important-decision/
well, technically you only figured out there is something wrong with your system "related" to gpu.
you could only be certain its the gpu by testing another 3080 (with at least similar power draw)
Just saying id try to be certain before rma, you never know what u get back (literally might just be the purchasing price in money)
Btw since im noticing u make a lot of topics about this without giving too much helpful information, is everything at stock settings, no overclocks, xmp etc?
Also can u list *full* specs, please?
-Scott Manley, 2021
First of could you list all your components and settings?
Have you looked at your frames because stuttering is pretty vague. Can you provide some actual FPS numbers?
Desktop: i9-10850K [Noctua NH-D15 Chromax.Black] | Asus ROG Strix Z490-E | G.Skill Trident Z 2x16GB 3600Mhz 16-16-16-36 | Asus ROG Strix RTX 3080Ti OC | SeaSonic PRIME Ultra Gold 1000W | Samsung 970 Evo Plus 1TB | Samsung 860 Evo 2TB | CoolerMaster MasterCase H500 ARGB | Win 10
Display: Samsung Odyssey G7A (28" 4K 144Hz)
Laptop: Lenovo ThinkBook 16p Gen 4 | i7-13700H | 2x8GB 5200Mhz | RTX 4060 | Linux Mint 21.2 Cinnamon
Its impossible for me to get my hands on a gpu similar to a 3080 at this time none of my friends own a similar one
SPECS:
B550 tomahawk
GX850 seasonic 80+ gold
Days gone and Control are on 2tb seagate hdd 700+ gb left
Fortnite and windows are on m.2 sata drive with 100+gb left
32gb 4x8 corsair rgb vengeance pro memory at 3200 mhz cl16 and xmp is on
MSI GAMING X TRIO RTX 3080 latest drivers on stock settings
Ryzen 7 5800x stock settings cooled by mag core liquid 360r
i pretty much am running a new copy of windows and its the latest version 21H1
B550 tomahawk
well for example without ray tracing on watch dogs my frames on ultra 1080p are around maybe 115 it drops from 115 to 100 for example in a second and my gpu usage and power drops then comes back.
ok, so u need to do classic troubleshooting…
strip down system as much u can.
1 or 2 sticks of ram , no xmp
remove harddrives  except OS drive
then check for a day or 2 if issues persist.
if they do its more than likely psu.
u can try testing this by setting a power limit (70-80%) or so *and* downclocking the "core clock" - 20 or so…
then check again if issues  persist
if they do, you'll probably need another psu.
or u just rma, which may or may not fix your problems (as said personally id want to make sure before doing that, and a psu is very cheap in comparison)
-Scott Manley, 2021
115 to 100 FPS seems fine to me.
What do you mean usage and power drops?  how much?
pretty much tried all that except removing drives and still stutters
21 minutes ago, InfernalClaw said:
well for example im at 97% usage and the game stutters and suddenly usage goes to 30% then comes back to 97%
Bios up to date ?
Gpu drivers up to date?
Since you already tried what Mark Kaine suggested it probably is power delivery then.
Which means PSU but it could also be inconsistent power delivery to the PSU.
I hate to say this but, are you sure? I mean the 1080 ti worked fine doesnt it mean the 3080 itself is the problem?
It would seem to suggest it but it could also be something like the power adapter
CPU: Core i9 12900K || CPU COOLER : Corsair H100i Pro XT || MOBO : ASUS Prime Z690 PLUS D4 || GPU: PowerColor RX 6800XT Red Dragon || RAM: 4x8GB Corsair Vengeance (3200) || SSDs: Samsung 970 Evo 250GB (Boot), Crucial P2 1TB, Crucial MX500 1TB (x2), Samsung 850 EVO 1TB || PSU: Corsair RM850 || CASE: Fractal Design Meshify C Mini || MONITOR: Acer Predator X34A (1440p 100hz), HP 27yh (1080p 60hz) || KEYBOARD: GameSir GK300 || MOUSE: Logitech G502 Hero || AUDIO: Bose QC35 II || CASE FANS : 2x Corsair ML140, 1x BeQuiet SilentWings 3 120 ||
LAPTOP: Dell XPS 15 7590
TABLET: iPad Pro
PHONE: Galaxy S9
She/they
could it be that the power supply itself is not i guess connected properly? or anything in my pc not connected properly?
@Mark Kaine @Doctor_Durf sometimes when the stutters happen, only the usage drops while the power remains constant
9 hours ago, InfernalClaw said:
you mean the cable? if its that then 1080 ti worked with it fine so why would it cause problems on a 3080?
1080ti is a 250 watt card the 3080 a 320 watt card.
Is your windows set to max performance?
Do you have access to another system where you could try the 3080 to see if the issues are exclusive to your system or if it also happens on other systems?
no i dont but update, i re tried the 1080 ti and it stuttered very badly actually on the same game the 3080 stutters on. i also tried newer memory still didnt fix it so i think its a software/game issue
6 minutes ago, RTX 3071 said:
Try to monitor power draw with MSI Afterburner and see if power draw drops with usage.
Confirm that if you have a modular PSU, you aren't using split cables like what I use:
Good Point.
Make sure you use 3 separate 8pin cables for your 3080.
Good Point.
203806876_4062655273771305_1944365734173116503_n.jpg.b2fcd05742bb23b89dddb614442d34ce.jpg
i think you may have found out what's causing me the problem. the one in the middle is coming out of the one on the right do you see that?
@RTX 3071
@RTX 3071
Was hard to recognize when I first saw this image but now it's really visible. Try 3 separate cables.
