Will that work? do i need a radiator or a stronger psu or really anything else?
CPU: AMD Ryzen 7 3700X 3.6Ghz AM4 - Box
CPU Fan: AMD Ryzen Wraith Stealth AM4
Motherboard: ASUS PRIME A520M-K AM4, AMD A520, DDR4, PCI-E, VGA, HDMI
Memory: HyperX FURY Black 2x8GB DDR4 3200MHz CL16 Kit
GPU: Sapphire Radeon RX 6800 PULSE 16GB OC GDDR6 HDMI 3xDP
HDD: Western Digital Caviar Blue 1TB Sata III WD10EZEX
SSD: Transcend SSD230S TS512GSSD230S SSD SATA III - 512GB
PSU: Corsair 1000W 80+ Gold RM1000x
Case: Sharkoon VS4-S ATX
Case Cooling: Corsair Air Series AF120 LED (2018) Red 120mm
Case Cooling 2: CoolerMaster MasterFan SF240R ARGB
Thank you.
https://linustechtips.com/topic/1350226-need-help-with-a-custom-pc-setup/
there is couple "problems" here
why not go b550? since youre using it with 3700x
why not go nvme with your ssd? its probably couple bucks higher than its sata counterpart for the same size
the psu is overkill, nothing wrong with that but its pretty overkill nonetheless you can go with 850w psu like enermax revolution d.f 850w and call it a day
i dont know about the case but it looks like it was going to be airflow hell
errr, youre going with air cooler so i dont know why you need radiator
also i dont know if youre typo but the 3700x comes with wraith prism not stealth, which is better, which is good
not the best, but atleast sufficient for normal non-oc use case
Stock HSF Overclocking : Test Perbandingan Cooler Bawaan AMD (Wraith PRISM  vs Wraith SPIRE vs Wraith STEALTH) • Jagat OC
01110100 01101000 01100001 01110100 00100000 01110111 01100001 01110011 00100000 00110111 00110000 00100000 01101001 01101110 01100011 01101000 00100000 01110000 01101100 01100001 01110011 01101101 01100001 00100000 01110011 01100011 01110010 01100101 01100101 01101110 00100000 01110100 01110110
Audio Interface I/O LIST v2
Thank you.
That PSU is way too overkill.
What is you country and budget?
geometry is hard
b550 > x570
will a STEALTH or a Arctic Freezer A13 X CO with be able to handle it still?
You mean prism?
Ethier way the Stealth definitely wouldn't do while prism will be "enough" for stock operations with good airflow
I don't know about the Arctic one tho
I personally have a 1800x and an Arctic eSports e33 - works pretty well, doesn't overheat and is mostly quiet.
CPU is a great choice!
CPU cooler: maybe even the Coolermaster 212? I wouldn't go stock cooler if I have to pair it with a 6800.
MB I would go higher on that, maybe even a B550 instead of B450, because of future proofing (PCIe 4.0)
Ram I agree on, good choice
GPU: Take what you can get, great choice!!
HDD: maybe take a 2TB one, not much more cost, but way more useful!
SSD: solid
PSU: could be overkill, maybe take the RM850X, save a few bucks and put them elsewhere
Case and cooler - I would take a more expensive case, with included fans. And also on with better airflow, so the RX6800 wont overheat. Fractal or cooler master should have somtheing for 50 60 bucks
Thank you.
