How to use AMD graphics card for gaming and Nvidia graphics card for output in a same PC?
Solved by Lisdraw69,
7 hours ago, LOST TALE said:Nevermind then. I was thinking you swap those for a single 4k monitor but that would be more expensive. Nvidia and AMD drivers should be able to run fine side by side. Just plug it in and hope all screens show up on Windows display settings! Not sure how to tell windows which to choose as primary gpu.
Ok I'll try. And will describe the outcome.
