Hey my dear friends,
On my Note 10+ charger it's written like on picture I attached.
So I don't understand,please explain me what voltage is used when charging the phone because here I see 3 different values,and dependant on what?
Explain me why are 3 different values shown on charger.
I'd also like to know is this powerbank okay to use as a portable powerbank for Note 10+ and for my tablet Samsung S5e and which ports on powerbank to use for charging devices?
https://www.ansmann.de/en/consumer/powerbanks/powerbank-15-ah-type-c-18-w-pd
Please do not take offence for my apparent confusion or rudeness,it's not intent me to be like that,it's just my BPD,be nice to me,and I'll return twice better,be rude and usually I get easly pissed of...I'll try to help anyone here,as long as it's something I dealt with,and even if you think I'm rude or not polite,forgive me,  it's not me it's my BPD.
Thanks for understanding.
https://linustechtips.com/topic/1349917-charging-voltagecurrent-difference/
5V is the USB standard.
9V is the Qualcomm Quickcharge 2 and QC3 alternative voltage.
12v is the QC3 QC4 voltage.
19v is the QC4/QC5 and USB PD voltage.
In order for QC2-3 and PD to work, your charger and your devices getting charged has to have establish connection via handshake, if your devices are incompatible simply they will charge at 5V.
EDIT: QC is quite a bit more diverse than what I portrayed here.
yes
Here is a basics video about volts watts and amps.
There's several charging standards  or protocols that can be used between a device (your phone) and a charger to negotiate a voltage and current.
Voltage x Current = Power ....
It's better to have a higher voltage and less current, because with more current, there's more losses in the wires.  You can counter those losses by either using thicker wires, or by reducing the current.
The charger will default on 5v and probably 1A, and the phone will start "talking" to the charger and depending on what standards both the device and charger support, they'll settle on a voltage and current.
Your phone will also pick a voltage and current depending on how charged the battery is.  For ex if it's almost empty then it may go to 12v 2-3A, but if the battery is 80% full it may stay at 9v or lower, because there's no need for higher voltage.
Like the person above me said, if both know QuickCharge 2.0, then QC 2 will be used. If QC3 is supported, then it will be used, if needed.
See https://en.wikipedia.org/wiki/Quick_Charge#Quick_Charge_for_Wireless_Power
If you buy a basic power bank, the ports will be 5v and probably up to 2-3A.
There are power banks with Quck Charge 2.0 or 3.0 , then the power bank will talk with the phone and agree on higher voltage/current pairs.
Gonna expound on this a little: 19V may be the QC4/QC5 voltage, but USB-PD ranges from 5V to 20V (specifically 5V, 9V, 12V, 15V, 20V), as negotiated be the device-to-be-charged.
Main System (Byarlant): Ryzen 9 5950X | Asus B550-Creator ProArt | EK 240mm Basic AIO | 32GB G.Skill DDR4 3600MT/s CL16 | XFX Speedster SWFT 210 RX 6600 | Samsung 990 PRO 2TB / Samsung 990 EVO Plus 4TB | Corsair RM750X | StarTech 4× USB 3.0 Card | Realtek RTL8127 10G NIC | Hyte Y60 Case | Dell U3415W Monitor | Keychron K12 Blue (RGB backlight)
Laptop (Narrative): Lenovo Flex 5 81X20005US | Ryzen 5 4500U | 16GB DDR4 3200MT/s (soldered) | Vega II 384SP Graphics | SKHynix P31 1TB NVMe SSD | Intel AX200 Wifi | Asus 2.5G USB NIC | Asus ProArt PA278QV | Keychron K4 Brown (white backlight)
Proxmox Server (Veda): Ryzen 7 3800XT | ASRock Rack X470D4U | Corsair H80i v2 | 128GB Micron DDR4 ECC 3200MT/s | 2× Samsung PM963a 960GB SSD / 4× WD 10TB / 4× Seagate 14TB Exos / 4× Micron MX500 2TB / 8× WD 12TB (custom external SAS enclosure) | Seasonic Prime Fanless 500W | Intel X550-T2 10G NIC | LSI 9300-8i HBA | Adaptec 82885T SAS Expander | Fractal Design Node 804 Case
Proxmox Server (La Vie en Rose)GMKtec Mini PC | Ryzen 7 5700U | 32GB Lexar DDR4 (SODIMM) | Vega II 512SP Graphics | Lexar 1TB 610 Pro SSD | 2× Realtek 8125 2.5G NICs
Media Center/Video Capture (Jesta Cannon): Ryzen 5 1600X | ASRock B450M Pro4 R2.0 | Noctua NH-L12S | 16GB Crucial DDR4 3200MT/s | EVGA GTX750Ti SC | UMIS NVMe SSD 256GB / TEAMGROUP MS30 1TB | Corsair CX450M | Viewcast Osprey 260e Video Capture | TrendNet (AQC107) 10G NIC | LG WH14NS40 BD-ROM | Silverstone Sugo SG-11 Case | Sony XR65A80K
Workbench (Doven Wolf): Lenovo m715q | Ryzen Pro 3 2200GE | 16GB Crucial DDR4 3200MT/s (SODIMM) | Vega 8 Graphics | SKHynix (OEM) 256GB NVMe SSD | uni 2.5G USB NIC | HDMI add-in module
Network:
                       ┌─────────────── Office/Rack ───────────────────────────────────────────────┐
Google Fiber Webpass ── Cloud Gateway Max ══╦═ Pro XG 8 ══╦═ Flex 2.5-8 ══╦═ Doven Wolf
                      La Vie en Rose (DNS) ═╬═ Narrative  ╠═ Veda-NAS     ╠═ La Vie en Rose (vmbr)
                                Veda (DNS) ─┘             ╠═ Veda (vmbr)  ├─ Ptolemy (vmbr)
╔═════════════════════════════════════════════════════════╩═ Ptolemy-NAS  ├─ Veda (Mgmt)
║   ┌ Closet ┐      ┌───────── Bedroom ─────────┐                         └─ Veda (IPMI)
╚═══ Flex XG ══╦╤═══ Flex XG ══╤╦═ Byarlant
       (PoE)   ║│              │╠═ Narrative
Kitchen Jack ══╣└─ Dual PoE ┐  │╚═ Jesta Cannon*
   (Testing)   ║┌─ Injector ┘  └── Work Laptop
     Bedroom ══╝│        ┌─────── Media Center ────────────────────────────┐
     Jack #2    └──────── Switch 8 ────────────┬─ nanoHD Access Point (PoE)
Notes:                                         ├─ Sony PlayStation 4
─── is Gigabit / ═══ is Multi-Gigabit          ├─ Pioneer VSX-S520
* = cable passed from Bedroom to Media Center  └─ Sony XR65A80K (Google TV)
yes
Okay.so this powerbank has QC 3.0.
Is that standard enough to charge my N10+?
Ok guys,thanks for such detailed info.
So basically I'm good to go with this Powerbank?
I hope Ansmann is okay,better then some Chinese crap they sell here...
So as the way I see it,I should use usb type C on power bank to charge my N10+,right?
But dunno which cable should I use,Samsung genuine one or the one which comes with Powerbank?
Both are type C.
Both are type C.
Well, both of them are fine
01110100 01101000 01100001 01110100 00100000 01110111 01100001 01110011 00100000 00110111 00110000 00100000 01101001 01101110 01100011 01101000 00100000 01110000 01101100 01100001 01110011 01101101 01100001 00100000 01110011 01100011 01110010 01100101 01100101 01101110 00100000 01110100 01110110
Audio Interface I/O LIST v2
ok guys,thank you so much.
Damn,I purchased wrong one.
The seller gave me the version Annsman Powerbank 15.8 where it's written USB Type C 5V max 3A.
I suppose I can not charge my Note 10 plus over type C port with this one,or?
https://www.techinn.com/en/ansmann-15.8-qc3.0-type-c-15000mah-powerbank/137805560/p
On tihs one that I purchased it's written that over usb type C only 5V-2A compared to the one on previous threads.
I suppose I can not use Ansmann version 15.8 to charge my Note 10 plus over usb type C,because only gives over type C 5V-2A,right?
Ahhh whatever,I oredered the previous one,and that is it...will wait for 2 weeks but what the hell..thx guys.
