Budget (including currency): $1600.00 usd
Country: United States
Games, programs or workloads that it will be used for: mostly games
Other details- My first pc I bought little over a year ago with was a omen prebuild from bestbuy with a 2080 in it but now I wanna build one and upgrade most of it. I plan on using the 2080 I have now due to prices of any other gpu lol. This is my current list of parts to buy feel free to make recommendations I appreciate them greatly!
Motherboard: Msi z490 gaming edge (wifi)
gpu: rtx 2080
cpu: i9 10850k ( didn’t see much of a difference between this and the 10900k besides price)
ram: 32g Corsair c16 3200 ddr4 (got it on sale)
AIO: Corsair H150I 360
SSD: Evo 970 2TB m.2
power: Corsair 850w
case: Corsair 5000x (yes a lot of Corsair I like there stuff lol)
I want this thing to be fast and load fast. I normally play on high graphics just because I don’t play on a high hertz monitor anyways. I’m hoping to have this build before battlefield comes out. Thanks to all that comment. Hope everything has a wonderful day!
https://linustechtips.com/topic/1349590-my-first-build/
gpu: rtx 2080
power: Corsair 850w
What is the “Corsair 850W”?
What is the SSD? A 970 Evo?
That case is really mediocre airflow wise, I’d switch to a different case with RGB and better airflow (P400A, P500A-D, Lancool Mesh,) or if you really want Corsair get the 4000D airflow.
geometry is hard
b550 > x570
https://linustechtips.com/topic/1349590-my-first-build/#findComment-14820244
Made a pcpartpicker version of your list.
You can cut a but of cost on the SSD if you want to , since paying a premium on the SSD for a gaming PC is not really worth much.
https://pcpartpicker.com/list/nQkxBc
PCPartPicker Part List: https://pcpartpicker.com/list/nQkxBc
CPU: Intel Core i9-10850K 3.6 GHz 10-Core Processor  ($406.00 @ Amazon
CPU Cooler: Corsair iCUE H150i ELITE CAPELLIX 75 CFM Liquid CPU Cooler  ($167.99 @ Amazon)
Motherboard: MSI MPG Z490 GAMING EDGE WIFI ATX LGA1200 Motherboard  ($225.99 @ Newegg)
Memory: Corsair Vengeance RGB Pro 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory  (Purchased For $0.00)
Storage: Crucial P1 2 TB M.2-2280 NVME Solid State Drive  ($243.87 @ Amazon)
Video Card: NVIDIA GeForce RTX 2080 8 GB Founders Edition Video Card  (Purchased For $0.00)
Case: Corsair 5000D AIRFLOW ATX Mid Tower Case  ($159.99 @ Amazon)
Power Supply: Corsair RMx (2018) 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($121.98 @ Newegg)
Total: $1325.8
Prices include shipping, taxes, and discounts when availabl
Generated by PCPartPicker 2021-06-22 09:12 EDT-0400
The case doesn't have really any glaring flaws, sure it's not the best but if it's more stylish for what OP is going for then it's alright.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1349590-my-first-build/#findComment-14820306
Of course you can build your system like that.
I also like to spend a little more money on quieter components or high quality ones.
But if I can save money and get the same or even better performance, I would save it.
Since you want to game on your PC, there will be no noticable difference from i7 to i9.
If you go for high end air cooling you can make your system quieter.
So if you go for i7 and maybe be quiet! Dark Rock Pro 4, you get the same gaming experience but you save $220.
If you love the RGB so much, that you want to spend the extra $220, feel free to do so, but even if I have the money, I would save it to have multiple nice dinners with my girlfriend or to get a better GPU.
My build:
CPU
Intel Core i7 9700 8x 3.00GHz So.1151
CPU cooler
be quiet! Shadow Rock Slim
Motherboard
MSI B360-A PRO Intel B360 So.1151 Dual Channel DDR4 ATX
RAM
16GB (4x 4096MB) HyperX FURY black DDR4-2666
GPU
8GB Gigabyte GeForce RTX2070 WindForce 2X 3xDP/HDMI
SSD
500GB Samsung 970 Evo Plus M.2 2280
HDD
4000GB WD Red WD40EFRX Intellipower 64MB 3.5" (8.9cm) SATA 6Gb/s
Power Supply
bequiet! Straight Power 750W Platinum
Case
Fractal Design Define R6
3x bequiet! Silent Wings 3 PWM
https://linustechtips.com/topic/1349590-my-first-build/#findComment-14820364
I only looked at this case because it comes with 3 Corsair fans which are $100 alone rather than buy them separately.
https://linustechtips.com/topic/1349590-my-first-build/#findComment-14820384
Total: $1325.8
I don’t mind the case you recommend but does it come with fans? I know the 5000x comes with 3 rgb Corsair fans which are expensive when bought separately.
https://linustechtips.com/topic/1349590-my-first-build/#findComment-14820386
If I were to go i7 which one do you recommend I currently have a i7 8700k in my prebuilt
https://linustechtips.com/topic/1349590-my-first-build/#findComment-14820389
I don't have any overclocking experience, so maybe someone else can answer that.
Personally I bought the 9700 non K last year for my build because it was the newest i7 back then.
Is there any game you play, which makes you think: "My CPU is too slow!"?
If not, you could just keep your current one until you feel like it's too slow.
But usually the GPU is the more important thing when it comes to gaming.
My build:
CPU
CPU cooler
Motherboard
RAM
GPU
SSD
HDD
Power Supply
Case
https://linustechtips.com/topic/1349590-my-first-build/#findComment-14820406
Ok I’ll have to mess around on bench test and see what comes up. I don’t plan to overclock anything because I don’t know how lol
https://linustechtips.com/topic/1349590-my-first-build/#findComment-14820414
Total: $1325.8
That P1 is pretty overpriced and a bit slow. The Mushkin pilot-E is much faster and is $20 cheaper. https://pcpartpicker.com/product/vkLwrH/mushkin-pilot-e-2-tb-m2-2280-nvme-solid-state-drive-mknssdpe2tb-d8
Look
s good otherwise
geometry is hard
b550 > x570
https://linustechtips.com/topic/1349590-my-first-build/#findComment-14820433
Look
s good otherwise
Ok so change that and you think it’d be a decent pc? Like I said I’m the post I want this boy to be fast and load quick ill use it mostly for gaming or movie watching lol
https://linustechtips.com/topic/1349590-my-first-build/#findComment-14820452
Then you can maybe save even more money.
Intel CPU with K are overclocking capable and usually cost extra.
If you will always use a graphics card, you can even go for a CPU with an F.
These don't have internal graphics and are even cheaper.
If you mainboard doesn't need to support overclocking, you might not need a Z one,
except you want it for it's other specs.
My build:
CPU
CPU cooler
Motherboard
RAM
GPU
SSD
HDD
Power Supply
Case
https://linustechtips.com/topic/1349590-my-first-build/#findComment-14820493
Well is over clocking worth it? Because I can definitely learn. I’ve done nothing for the past week besides look up build guides and everything in between lol
https://linustechtips.com/topic/1349590-my-first-build/#findComment-14820499
There are many opinions about that.
My opinion is: No.
If you go for AMD, overclocking is always possible (I think).
If you go for Intel, it costs extra.
You get a little more clock speed, which improves performance but you also need more power to run your system.
Intel Turbo Boost already automatically increases your CPU clock when needed, so you save energy when you dont need it and it will lower the clock speed.
Also if you overclock too high, your system can crash and become less reliable.
So you would pay more money for some extra performance but also extra power consumption and less reliability.
My build:
CPU
CPU cooler
Motherboard
RAM
GPU
SSD
HDD
Power Supply
Case
https://linustechtips.com/topic/1349590-my-first-build/#findComment-14820515
