ok so like this is probably going to sound like a very dumb question, but i have no idea how this stuff works so hear me out.
I have a b450 gaming pro carbon max wifi mother board, which houses an extra 4pin slot for the cpu aswell as the 8 pin one ( im using a ryzen 3 3200g btw) and my power source is a modular power source but does not have 4 extra pin slots dedicated for this kind of thing. But i was thinking, hypothetically if i the right cable, could i plug the cable into 4 unused slots which were intended for ssd's?
does it work like that?, also im using the onboard graphics of my cpu so im not getting a graphics card, so could i just plug something into the unused 24 pins for the graphics card? idk call me crazy but i made a diagram in microsoft paitn incase that didnt make any sence
(once again im a noob lol)
(edit - also would it be possible to overclock without the extra 4 pins, i was looking on forums and people were saying you just need the extra 4 pins for like "mega extreeme" overclocking, and seeing as my cpu only clocks to 4.0 max i feel like i should be fine right? or does onboard graphics suck up alot of power
Also just incase i want to change it later what is a powersource that does have the extra slots for the cpu)
Corsair doesn't make those cables, so I'd definitely not recommend trying to find some cable that goes from the SATA/peripheral port to 4 pin EPS.
The 4 pin EPS is not needed.
The 8 pin EPS connector does up to 384W already, while a 3200G does not use even more than 80 or so watts.
Even when overclocking or using the built-in graphics of the 3200G, without the 4 pin you're just fine.
oh cool thanks so much
Those Extra cpu pin is only necessary if you have a beefy CPU and want to overclock it hard
Just using the 8 pin is perfectly fine for your use case
01110100 01101000 01100001 01110100 00100000 01110111 01100001 01110011 00100000 00110111 00110000 00100000 01101001 01101110 01100011 01101000 00100000 01110000 01101100 01100001 01110011 01101101 01100001 00100000 01110011 01100011 01110010 01100101 01100101 01101110 00100000 01110100 01110110
Audio Interface I/O LIST v2
