Perhaps it would be a good idea to tell us what mouse you're using.
Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy.  If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear.
https://linustechtips.com/topic/1349313-cant-click/#findComment-14817925
4 minutes ago, chips1337 said:
CPU: I5 2500K
GPU: GTX 1060 6gb
RAM: 16GB DDR3
MOTHERBOARD: P8Z68-V GEN3
PSU: 650W CHIEFTEC
Windows 10 is installed on a 120gb
kingston ssd
Basically i can't click on anything but i can use my keyboard
Can you move the cursor around and just cant click or is the mouse completely dead? Try another USB port
https://linustechtips.com/topic/1349313-cant-click/#findComment-14817928
My bad, Logitech g pro wireless
I can move it around, windows just won't let me click on anything.
https://linustechtips.com/topic/1349313-cant-click/#findComment-14817976
