3 minutes ago, Jman4004 said:
I wanna make a computer but I can't find a tutorial to wire it all up any suggestions
Have you tried the channel that owns this forum?
https://pcpartpicker.com/list/Qm9Mwc
Main Project:
A desk that has a hatch that opens in the middle of it and then goes down flush with the desk.
Other projects I am working on
  • Sleeper TI-99 4A
  • Second Keyboard
https://linustechtips.com/topic/1348917-please-help/#findComment-14815142
There are, probably not exaggerating here, hundreds of PC build guide tutorial videos on YouTube.
Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy.  If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear.
https://linustechtips.com/topic/1348917-please-help/#findComment-14815160
this is one of those lost internet users thing... like the forum is literally devoted to a youtube channel with its own build guides...
My profile picure is real. That's what I look like in real life. I'm actually a blue and white African Wild Dog.
Ryzen 9 5900X - MSI Ventus 2x OC 3060 Ti - 2x8GB Corsair Vengeance LPX 3200MHz CL16 - ASRock B550 Phantom Gaming ITX/ax
EVGA CLC 280 + 2x140mm NF-A14 - Samsung 850 EVO 500GB + WD Black SN750 1TB - Windows 11/10 - EVGA Supernova G3 1000W
https://linustechtips.com/topic/1348917-please-help/#findComment-14815169
Just now, Jman4004 said:
I have, but in all of them he doesn't go into detail
Perhaps you could elaborate on what specific parts of the process you are unclear on.
https://linustechtips.com/topic/1348917-please-help/#findComment-14815176
1 minute ago, Jman4004 said:
Wiring up all the pins
Like the 24 pin power one
You connect it to the 24 pin header on the motherboard.
No other header looks remotely like it, and there is a clip that only allows it to go in one way (or at least it will be immediately obvious if you're trying to put it in backwards).
It's possibly the simplest part of cabling/wiring.
Anything else?
https://linustechtips.com/topic/1348917-please-help/#findComment-14815184
Every cable on your PSU should be labled as well as the ports on the motherboard, and your motherboard manual will also include this. The 24-in, 8/4 pin CPU cable in the top left, sata power cables for drives, should all be obvious and covered in videos. The hardest cables are usually front panel connectors. This is a decent video if you just need to know those.
Front Panel Connectors On Motherboard - Easy Beginners Full PC Building Tutorial - Pt 19 - YouTube
https://linustechtips.com/topic/1348917-please-help/#findComment-14815185
Pin
Anything else?
Do you have a tutorial I'm sorry but that was just an example of what I was thinking of I mean like all of the wiring for a intel
https://linustechtips.com/topic/1348917-please-help/#findComment-14815189
wiring for a intel
AMD and Intel are gonna be wired exactly the same. Ever computer is gonna have the main large 24 pin on the left side, the only difference is if you have an 8 pin or 4 pin connection in the top left and these are usually square shaped and the only wire connections in the top left.
Also LTT has a first person POV video where hes puts a computer together this is right after the cable management he did.
https://linustechtips.com/topic/1348917-please-help/#findComment-14815192
Thanks this will work great
https://linustechtips.com/topic/1348917-please-help/#findComment-14815199
Also do want to note, cable management is not super necessary unless your looking for the best possible temps and are overclocking. I've done plenty of "rats nests" where all my cables are just a mess towards the bottom of the case and come up to where they need to go.
https://linustechtips.com/topic/1348917-please-help/#findComment-14815207
OK thanks for the info
https://linustechtips.com/topic/1348917-please-help/#findComment-14815227
