Amd kaveri APU ultimate build guide cooling fail?
Solved by atrash,
Doesn't matter which orientation the cpu cooler is. Hot air rises so even if the cpu fan/cooler is facing towards the rear case fan, it will still recirculate the hot/warm air from the graphics anyhow. Plus, it's the only way to mount that cooler on an AMD motherboard because of the mounting mechanism. I wouldn't call it a cooling fail.
Featured Topics
TridentTank88 ·
Posted in Graphics Cards1 -
Nov845 ·
Sanderdrejer ·
Posted in Troubleshooting2
play_circle_filled
Latest From ShortCircuit:
Lian-Li, do this on all of your cases! - Lian-Li O11D x Lamborghini
