Dual monitor question
Solved by PorkishPig,
1 minute ago, Sima01 said:Im 50% sure it will work since I can't tell if that Display Port is just a duplicate of that HDMI or something. Never used dual monitor with a PC.
Each output on your graphics card can be used for a single display. Your OS will control whether or not you will see a duplicate output on multiple monitors.
Featured Topics
INotPablo ·
Posted in Peripherals1 -
LT2 ·
Posted in Laptops and Pre-Built Systems4 -
7
joshfrog ·
Posted in Mobile Gaming5 -
5
1
f23948 ·
Posted in Programs, Apps and Websites3 -
1
1
