Would two d5 pumps 2X480 mm rads a 240 and a 420 Be enough to passive cool a 5900x and 3080?
Solved by Stahlmann,
As long as there is no moving air around the radiators, they won't cool much. Even your case with all rad spots filled will likely not be enough to cool your system long-term. It might work for short loads, but after a few hours it will get warmer and warmer. Just get nice and quiet fans like Noctua NF-F12 and run them at 500 RPM where they are not audible. Then you can just use 1 or 2 rads and the temps will be fine.
