Hey guys! I recently got my hands on a gtx 295 that has some issues. When running in multi-gpu mode, full screen games show green boxes all over the place. But when i disable it, the green boxes don't come up. have any of you had this problem before? what did you do to fix it? I have a c2d e7200, 4 gigs of ram, a gigabyte board (dont remember which one), and a 750w psu.
https://linustechtips.com/topic/134687-issues-with-gtx-295/
why did you buy a 295?
-The Bellerophon- Obsidian 550D-i5-3570k@4.5Ghz -Asus Sabertooth Z77-16GB Corsair Dominator Platinum 1866Mhz-x2 EVGA GTX 760 Dual FTW 4GB-Creative Sound Blaster XF-i Titanium-OCZ Vertex Plus 120GB-Seagate Barracuda 2TB- https://linustechtips.com/main/topic/60154-the-not-really-a-build-log-build-log/ Twofold http://linustechtips.com/main/topic/121043-twofold-a-dual-itx-system/ How great is EVGA? http://linustechtips.com/main/topic/110662-evga-how-great-are-they/#entry1478299
https://linustechtips.com/topic/134687-issues-with-gtx-295/#findComment-1791465
Probably got it off a mate, and for cheap too. And its still an OK card. Its about equivalent to a 7770 or a 650, which is more than enough for basic gaming. Provided the game supports DX10 of course, and SLI.
Also known to his peers as Lord Scrubby McScrubington
https://linustechtips.com/topic/134687-issues-with-gtx-295/#findComment-1791547
maybe try to reduce the core clock, and then try again
will try this thanks
i pulled it from my bff. she does more content creation stuff and already had a quatro so she didnt really need it
edit: alright so i tried lowering the core clock then ran furmark and i still get the same issue. any other ideas?
https://linustechtips.com/topic/134687-issues-with-gtx-295/#findComment-1792444
