I have a media console and will place my receiver and gaming rig in there. It will get hot, even with the back off.
Id like to put in some effective, but quiet fans. 2 on bottom to suck in cooler air, and 2 on top to pull out hotter air.
What are decent fans that i can screw in? Id need an adapter to plug them in wall.
https://linustechtips.com/topic/1346685-media-console-cooling/
I think the OP means 'Entertainment Unit' when they say 'Media Console'?  Like the piece of furniture?  I.... Think?
Desktop: Ryzen 9 3950X, Asus TUF Gaming X570-Plus, 64GB DDR4, MSI RTX 3080 Gaming X Trio, Creative Sound Blaster AE-7
Gaming PC #2: Ryzen 7 5800X3D, Asus TUF Gaming B550M-Plus, 32GB DDR4, Gigabyte Windforce GTX 1080
Gaming PC #3: Intel i7 4790, Asus B85M-G, 16B DDR3, XFX Radeon R9 390X 8GB
WFH PC: Intel i7 4790, Asus B85M-F, 16GB DDR3, Gigabyte Radeon RX 6400 4GB
UnRAID #1: AMD Ryzen 9 3900X, Asus TUF Gaming B450M-Plus, 64GB DDR4, Radeon HD 5450
UnRAID #2: Intel E5-2603v2, Asus P9X79 LE, 24GB DDR3, Radeon HD 5450
MiniPC: BeeLink SER6 6600H w/ Ryzen 5 6600H, 16GB DDR5
Windows XP Retro PC: Intel i3 3250, Asus P8B75-M LX, 8GB DDR3, Sapphire Radeon HD 6850, Creative Sound Blaster Audigy
Windows 9X Retro PC: Intel E5800, ASRock 775i65G r2.0, 1GB DDR1, AGP Sapphire Radeon X800 Pro, Creative Sound Blaster Live!
Steam Deck w/ 2TB SSD Upgrade
https://linustechtips.com/topic/1346685-media-console-cooling/#findComment-14798543
there are wall adapters to PC fans. the fans will only run at 100% using them. so I would probably get silent focused fans and good positive pressure. probably the best pick would be arctic p12 silent or p14 silent. no need for the pwm versions as they can only run 100% anyways.  p12 is 120mm p14 is 140mm.
https://linustechtips.com/topic/1346685-media-console-cooling/#findComment-14799774
