I have changed my motherboard recently and ever since I have had way too man Blue screens for what seem like no reason at all.
After changing to the motherboard I made sure to do a clean install of windows and cleaned my drives. I then reinstalled all the drivers that I think I needed including graphics, chipset drivers, and audio drivers.
The crashing seems to happen mostly when I am benchmarking or playing a game but it also happens when I am just using chrome. What happens during the crash is my mouse stops working, the audio cuts out then it either freezes or gives me a blue screen.
Error codes I have gotten
Critical process died
system service exception
c;\windows\system32\logfiles\srt\srttrails.txt
win32kfull.sys failed
Specs
2700x
16gb 3200mhz ram
b450i asrock fatality
3080 fe
1tb samsung ssd
also using gen 4 riser cable
What I have test
Memtest86 showed no problems
ran cpu stress test for an hour with no fail
Firestrike sometimes crashes but it is very inconsistent
WhoCrashed conclusion says to update graphics drivers and also hardware.sys which I don't understand
This issue also goes away sometimes, I have gone a whole day with out it showing up but the next day it happens more than ever060721-6109-01.dmp
https://linustechtips.com/topic/1345596-constant-bsod-please-help/
1 hour ago, Radium_Angel said:
Are you using XMP in the BIOS? If so, turn that off
XMP was already disabled but decided to lower the ram speeds to 2400 and I still ran into the same issue.
Im going to rebuild the pc without the riser and see if that is the problem
