Please help
Go to solution Solved by LogicalDrm,
-> Moved to Troubleshooting
I would like to ask if you could help me. I have a pc that been shutdown for 12 time because the electricity is on and off because of the typhoon. I have no choice but to open it every tine the electricity came back because i have a deadline work . The hdd is now dead ive tried to replace it with my other hdd but it really wont open anymore . What should i do??? Help please
https://linustechtips.com/topic/1345289-please-help/
Did you have an existing backup of the data? If not, then the only option is to pay up for a data recovery from either your local repair shop or some other trustworthy shot.
If you can't do either of that, you are out of luck unfortunately.
Don't call me a nerd, it makes me look slightly smarter than you
https://linustechtips.com/topic/1345289-please-help/#findComment-14787589
8 hours ago, Caroline said:
care to explain how do you came to the conclusion that the hard drive is dead?
also, what are your specs?
The hard drive won't open i put it in another pc it can't be detected . I have an old i5 1st gen  mother board asus.
https://linustechtips.com/topic/1345289-please-help/#findComment-14788186
did you try different sata power and data cables? If you already tried that, then try using another sata port on your motherboard.
https://linustechtips.com/topic/1345289-please-help/#findComment-14789415
