I used MSconfig  to get into safe mode  . I clicked the restart button, after the pc restarted i was getting a black screen
Luckily i was able to do screen share using my Discord by using narrator to navigate.
All my drivers are missing please advise
P.S : My GPU is not working and i was using integrated graphics Screenshot_20210605-014605_Discord.thumb.jpg.c53dd7270222ea0acdeb60cc8997e63e.jpg
https://support.microsoft.com/en-us/windows/start-your-pc-in-safe-mode-in-windows-10-92c27cff-db89-8644-1ce4-b3e5e56fe234
That's expected in safe mode.
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
When you are in safe mode it reverts to basic integrated OS drivers, hence the "Safe" part.
For what reason are you in safe mode for?
 CHRISTIAN MEMBER
delete the card from Device Manager, remove current drivers and download the originals first and reboot.
Make sure power cables are fully in the card and card is pushed all way in and not sagging.
Clean the fan(s) wiht compressed air.
Baring this, your GPU could be borked.
