SOMEONE HELP
Go to solution Solved by Moonzy,
Just now, OzZy15 said:
It shuffles between聽
馃 You may try reseating your RAM
Do you know what RAM is?
It's the two long vertical sticks that's golden in color from your first photo
There should be a tab on top of the stick, there's a flange there that you can push down and the RAM should pop out on that side
Check for similar flange on the bottom side, some boards have it, some don't
Once you pushed then flange(s) down, pull the RAM out slightly, then push it back in
It requires a bit of force and you know it's in when you either hear an audible click, or the flange will automatically go back up into "locked" position
You may try one stick at a time, remove one stick entirely if it doesn't work after reseating both
If this doesn't work, I'll have to recommend you refer back to cyberpower, especially if it's still under warranty, but do remember to plug your hard disk back in beforehand
As you may have to do CPU reseating and that requires thermal paste, which you may not have(?)
My dog ran into my computer and immediately froze my computer. I also heard something when it froze in my headphones like it just stopped every single sound. I later turned it on again and it happened again a little bit later. But this time, even though it turns on, my monitors don鈥檛 display. Please anyone help
https://linustechtips.com/topic/1344448-someone-help/
Ouch, you comfortable opening up your case? It might have dislodged your GPU. Also you using SSD's or mechanical HDDs? Also may sound silly, but did you check your monitor cable?
RYZEN 7 3700X / MSI X570S TOMAHAWK MAX WIFI / ZOTAC 3070 TWIN EDGE OC / CORSAIR VENGEANCE RGB PRO 32GB @ 3200 / SAMSUNG 980 PRO M.2 / WD BLACK SN850 M.2 / GIGABYTE P750GM 80+ GOLD / MSI MAG FORGE 100R / MSI MAG CORELIQUID 240R聽
https://linustechtips.com/topic/1344448-someone-help/#findComment-14781505
5 minutes ago, Moonzy said:
how familiar are you with PC, and are you comfortable with poking around in it?
I am comfortable opening it up and I have already but don鈥檛 know what cable I have to touch on the gpu, in fact my monitor is on but it now a black screen, but only my main monitor not my second
https://linustechtips.com/topic/1344448-someone-help/#findComment-14781515
a photo might help spot easy to spot issues
-sigh- feeling like I'm being too negative lately
https://linustechtips.com/topic/1344448-someone-help/#findComment-14781518
7 minutes ago, OzZy15 said:
Which one
2nd photo looks blurry, but that's probably it
you can unplug both cables on it
the smaller connector has a lock on it so you can press down on the metal bit on the connector before you pull
https://linustechtips.com/topic/1344448-someone-help/#findComment-14781561
I can only seem to unplug the one with the lock on it, I can鈥檛 get a good grip on the big one but I can keep trying
https://linustechtips.com/topic/1344448-someone-help/#findComment-14781564
When you unplug your second monitor and only boot with your main monitor attached, can you boot? Does it display anything at all?
https://linustechtips.com/topic/1344448-someone-help/#findComment-14781578
2 minutes ago, OzZy15 said:
Do u want me to plug them back?
Boot without the hard drive(s) connected, are you able to get anything to show on the screen during boot-up?
https://linustechtips.com/topic/1344448-someone-help/#findComment-14781589
Not the hard disk, leave that unplugged
Try to boot without HDD plugged in
When booting, you can pay attention to the top right of the motherboard, there may be some LED that moves, and if it stays lit on certain one and there's nothing on screen, do let me know which one is it
https://linustechtips.com/topic/1344448-someone-help/#findComment-14781591
It is flashing over DRAM and CPU and my monitor is not automatically turning on
https://linustechtips.com/topic/1344448-someone-help/#findComment-14781597
What CPU do you have?, which Intel chip. You have a VGA/DVI port on your motherboard. If you have onboard graphics you could try to connect your monitor directly to the board and see if you have a display out there.
https://linustechtips.com/topic/1344448-someone-help/#findComment-14781608
I have a Intel I-7 10700F with no motherboard graphics
https://linustechtips.com/topic/1344448-someone-help/#findComment-14781609
https://linustechtips.com/topic/1344448-someone-help/#findComment-14781610
Legend you are, restarting my ram did the work, you are a god 鉂わ笍
https://linustechtips.com/topic/1344448-someone-help/#findComment-14781616
