Further progress on my future LAN build. Sleeper!
Draelren
AMD Ryzen 7 4700G
ASRock Phantom Gaming X570 ITX/TB3
G.Skill Trident Z Neo 16GB 3600MHz
WD Black SN750 1TB
HDPLEX 400W DC-ATX PSU
MB Custom Sleeving - 8 Pin EPS
Bitspower ASRock X570 ITX/TB3 Monoblock
Bitspower G1/4" to 3/8" Barb Fitting, 90° Rotary
Bitspower G1/4" Extender Fitting 15mm
Bitspower G1/4" to 3/8" Barb Fitting, 2 Pack
Alphacool G1/4" to 13mm OD, 90° Rotary
EKWB EK-DuraClear Soft Tubing, 10/13mm (3/8" ID, 1/2" OD), 3 Meter, Clear
Alphacool Eisstation 40 DC-LT
Alphacool NexXxoS XT45 Full Copper 50mm Dual Radiator
GELID Solutions Silent5 FN-SX05-40 50mm
[Main Work / Play: Phanteks Evolv X | Ryzen 5950x | NZXT Z73 AIO | 64GB 3200MHz G.Skill Trident Z | EVGA RTX 3070 XC3 | Asus Crosshair VIII Dark Hero | 4.5TB SSD Storage]
[Wife's System: Asus RoG Z11 | Ryzen 5800X | NZXT Z53 AIO | 32GB 3600MHz S.Skill Trident Z Neo | Asus RTX 3060 Ti Dual OC | Asus RoG X470-I Gaming | 2TB SSD Storage]
[Personal Portable / LAN System: Xbox One S | Ryzen 4700G | Full Custom Loop | 32GB 3600MHz Patriot Viper Steel | ASRock Phantom Gaming X570 ITX/TB3 | 2TB Patriot Viper VP4300]
[Wife's Portable / LAN System: Playstation 3 | Ryzen 5 Pro 5700G | Full Custom Loop | 32GB 3600MHz Patriot Viper Steel | ASRock Phantom Gaming X570 ITX/TB3 | 2TB Patriot Viper VP4300]
Was wondering why it would be a sleeper bit then I noticed it's on an Xbox enclosure! Cool stuff.
No dedicated gpu though, that makes it really hard to compete with an actual console 😄
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
Got a razer core v2 to use with a 3000 series GPU should I need. 🙂
Noice!
What are your Temps with this tiny radiator? I have a real struggle keeping my 3900X cool with a dual 120 😄
Gaming HTPC:
Desktop PC:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
3 hours ago, FloRolf said:
Noice!
Current idling between 27-28c.
It was idling originally in the 40s, then 30s, now down into the 20s as the air bubbles work their way out of the system.
