Help With Wired Connection Not Appearing After Reboot
Solved by cichington,
On 6/2/2021 at 10:51 AM, ramava said:Yeah. Assuming it's a wireless router, it would have to be outside of the box. I wasn't even thinking about the WiFi originally.
So after some troubleshooting, it turns out the ethernet jack I was originally using was either damaged or not run correctly. Thankfully there was another jack close by that worked and I have been able to get a stable connection. Thanks for the recommendations on troubleshooting!
