i have an i5 4570s, 8gb ram and a hdd. i'm planning to buy a ssd. get my ram in dual channel and that's about it. i am going to be editing 1080p or 720p. is this configuration good enough. (i wont be using any affects or anything just stitch it together to make a video). i really just need help
https://linustechtips.com/topic/1343824-i-need-help/
I think it's going to be fine. I edit my videos using an i5 6200U, so, if you increase RAM and put an SSD, you'll be in an even better position. I even edited using 8 gigs of RAM and an HDD before upgrading to an SSD. It was fine for my purpose with the hardware.
Attention is what makes life meaningful.
Also, please quote me for a reply. 🙂
https://linustechtips.com/topic/1343824-i-need-help/#findComment-14776160
What capacity are you looking for?
What's your budget?
Check this thread:
On 4/5/2024 at 10:13 PM, LAwLz said:
I am getting pretty fucking sick and tired of the "watch something else" responses. It's such a cop out answer because you could say that about basically anything, and it doesn't address the actual complaints. People use it as some kind of card they pull when they can't actually respond to the criticism raised but they still feel like they need to defend some company/person. If you don't like this thread then stop reading it. See how stupid it is? It's basically like telling someone "shut the fuck up". It's not a clever responsive, it doesn't address anything said, and it is rude.
MKBHD is but an Apple propagandist and fanboy. Take his videos with a grain of salt, especially about anything Apple. In his video titled "I Visited Apple's Secret iPhone Testing Labs!", he has shown that he makes no effort to fact check Apple's claims, and takes it at face value. I do not believe he can be trusted as an Reviewer/Influencer.
bruh switch to dark mode its at the bottom of this page
VPN Server Guide
https://linustechtips.com/topic/1343824-i-need-help/#findComment-14776164
5 minutes ago, techzoide said:
thankyou so much man. although my 8gig stick is in single channel so i'll get that done in dual channel
Just get another 8 gigs of matching RAM, and an SSD, preferably of 500 gigs, so that you can have your OS on it, as well as put video files while you can edit them. I don't know how large they will get. Something like a Crucial mx500 should do just fine, without breaking the bank.
https://linustechtips.com/topic/1343824-i-need-help/#findComment-14776187
2 minutes ago, techzoide said:
yeah ok but i have an external hdd too so i will probably get a 256gb something like maybe a 840 or a 860 evo. to be honest 1 video will probable be of about 1 to 2 gigs so i think i should be fine
WD Blue, 860 Evo, MX500, 840 Evo 870 Evo, whatever you find cheapest on the day of purchase, go for that. They're all equally good. Samsung is generally a bit too pricey.
https://linustechtips.com/topic/1343824-i-need-help/#findComment-14776201
