Monoprice Liquid Spark for Sennheiser HD 6xx: Good idea? (+Need a DAC)
Crackling at high volumes sounds like a hair is caught in the headphone driver. You may want to consider tearing it down and checking for that before spending more money.
For 300Ω loads the Magni 3 is better than the Liquid Spark in virtually every measurable aspect, not just corner cases, and the Magni Heresy significantly better still.
If you do still decide to buy a DAC/amp around that price point, and are purely chasing objective measured performance for the money:
The Sabaj a10h might be worth looking into; its amplifier circuit is a clone of the Topping L30, currently the highest SINAD amplifier on Audiosciencereview, and manufacturer measurements appear to confirm a comparable performance level. I believe a unit is waiting for review at ASR at some point if you want to wait for that. Cheaper than the Liquid Spark on Amazon.com.mx. Edit: The a10h appears to have a poor grounding layout or power supply coupling to mains power, giving it high mains noise. Even though the amplifier circuit itself performs on-par with the L30 and the problem could probably be fixed cheaply with a lower leakage wall power supply, I can't recommend it as highly given these issues.
The Liquid Spark DAC, Modi, and JDS Atom aren't available on Amazon.com.mx. If Aliexpress is an option and you resample to 48kHz, the Meizu hifi dongle performs on par with the above for about $25USD. The Tempotec Sonata HD Pro is a dongle at about the price you're looking for with comparable performance, but you might feel that the dongle setup with 3.5mm out instead of RCA is a bit janky. The SMSL Sanskrit 10th Mk II is about $150USD and performs slightly better than the above in most measures but has low frequency IMD issues that make me reluctant to recommend it. Khadas Tone Board and Topping D10 are also good candidates around that price.
