I have recently finished pouring all of my money into this PC, and it is functioning very well and I've gotten it pretty much dialed in; except for the RAM. My kit is rated at 3200 MHz, but I've only been able to boot the system when it's running at 2133 MHz. Switching to the XMP profile will restart it, but I can't even get into the BIOS again without removing the CMOS battery. I've already tried updating the BIOS, but I can't figure out what to do.
Here are my system specifications:
CPU: Ryzen 5 3600
CPU Cooler: Corsair H100i Elite Capellix
RAM: Corsair Vengeance RGB Pro (32 GB, 4x8, 3200 MHz)
Motherboard: MSI B550-A Pro, BIOS version 7C56vA6
GPU: Gigabyte RTX 3060 Gaming OC 12 GB
Storage: Samsung 970 EVO 1TB M.2 x 2, Samsung 870 EVO 4TB SSD
PSU: Corsair RM850 850W
-------Update------
Dialing down RAM speed didn't work, the only way to get the system to boot is with XMP disabled, at stock speeds of 2133 MHz. I'm thinking maybe my motherboard is just not equipped to run at full speed, although I was able to enable XMP for 3200 MHz when the build only had a 2x8 16GB RAM setup. Any advice is much appreciated.
Edited by MikachuXIII
adding more system specs, attempted fixes to no avail
https://linustechtips.com/topic/1343210-ram-speed-help/
your cpu should be able to run 4x stikc at 3200mhz. Are you sure you have the newest bios?
also try enbaling XMP but then dial bakc the ram frequenzy to 3000mhz and try again
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
https://linustechtips.com/topic/1343210-ram-speed-help/#findComment-14771166
enabling XMP causes the failure to boot, I'll try dialing back frequency though. I am also on the latest bios
https://linustechtips.com/topic/1343210-ram-speed-help/#findComment-14771179
9 minutes ago, Dhanji said:
advice me.
DDR-3200 is 1600MHz x2 .. DDR stands for Double Data Rate. . With yours at 1596 you're good.
RYZEN 7 3700X / MSI X570S TOMAHAWK MAX WIFI / ZOTAC 3070 TWIN EDGE OC / CORSAIR VENGEANCE RGB PRO 32GB @ 3200 / SAMSUNG 980 PRO M.2 / WD BLACK SN850 M.2 / GIGABYTE P750GM 80+ GOLD / MSI MAG FORGE 100R / MSI MAG CORELIQUID 240R
https://linustechtips.com/topic/1343210-ram-speed-help/#findComment-14782112
