Using a CoolerMaster V8 for an LGA 1151 socket
sixtailfox
Hi, so this is my first post so be kind if I´m not that familiar with the rules.
So my cousin gave me his old pc and i was looking to maybe reuse some of the parts if they were still usable.
The parts that Ipm most interested about is the cooler a Cooler Master V8, i think its the first version since it only has 1 fan in the middle.
The power supply : a Cooler Master Real Power Pro RS-750-ACAA-A1 750W
And the Computer case a CoolerMaster Cosmos 1, the one with silver side panels, I thik the next version had side vents or something
So what I wanted to ask in this forum was
The cooler stated that its compatible with cpu sockets such as lga ,1366,1155, 775
Is there any compatibility problems with installing it to a i7 in a lga 1151 socket type?
I think there is no difference with the mounting brackets for the 1155, unfurtanately i only have the  1366 brackets, so any idea where i could get the 1155 in case its all ok?
In case any one was wondering about the parts of the old PC:
MB: gigabyte ga-ex58-ud5
CPU: Intel Core i7 928
Memmory: 8 Gb in different formats mostly some chineese brand
Video Card: Power Color HD 4870
Power Supply: Cooler Master Real Power Pro RS-750-ACAA-A1 750W ATX12V / EPS12V SLI Certified CrossFire Ready 80 PLUS Certified Active PFC Power Supply
All 115x mounting holes are the same, 1155/1156/1150/1151
You can check eBay for the cooler master v8 mounting hardware but it might be a hard find, there’s a kit on there I just searched up but it ships from the Netherlands so it’s like 30$ with shipping to the US anyway.
