Odd power cycle
Solved by Not_nice2u,
11 hours ago, GorujoCY said:oh I did mean only the 4gb stick and keep the 2 8gb stick.
there's sometimes issues that come down when mixing ram so it's a good course of first action to try since you did the rest.
Tried that as well with no results. The thing is I figured if it's power cycling just with power and cpu connected it must be either cpu or motherboard. Otherwise it would just beep/error code because of missing components? That one successful turn on without power cycle confused me, but I'm out of ideas besides it's a motherboard fault.
