Budget (including currency): <$800
Country: USA
Games, programs or workloads that it will be used for: Simulator Games— specially F1, Assetto Corsa, Flight Sim 2020.
I understand the graphics card world is upside down right now but looking to get back in sim games. I want to be able to play these on high+ settings on a 34” ultra wide 3440x1440 monitor. Anything in the secondary market worth buying right now, or should I just hold off for a 3080 when and if I can get one?
https://linustechtips.com/topic/1342817-sim-graphics-help/
Racing games usually don't have very high hardware requirements.
Mostly mid level GPU will play it at ultra.
Flight sim is another beast.
A 3080 will be good for those games.
When? Up to you, i suggest waiting until end of quarter 3.
https://linustechtips.com/topic/1342817-sim-graphics-help/#findComment-14768624
MS Flight sim 2020 is apparently not built like other games and getting it to run faster than 30fps on just about anything is just hard.  There’s been a great deal of research on this thing but not a lot of useful results.  One would think that it would be a common benchmark like crisi became simply because it was hard to run. It so different from everything else though that It’s not terribly useful that way.  It’s kind of like Theres MS flight sim 2020 and then there’s everything else.
If racing games are easy to run it would seem like the thing to do is build a machine specifically for MS flight sim 2020, and then just run other things on it because you can.  What exactly is required to make flight sim 2020 work well though I’m afraid I do not know.
https://linustechtips.com/topic/1342817-sim-graphics-help/#findComment-14768660
Everything on the second-hand market is selling at +200% it's original market value because of the chip shortage. Hold off and try to get a Founders Edition card, those are the only ones that're price regulated at MSRP when available (from BestBuy or NVIDIA directly). Go for the 3080, but don't pay more than $800 for one, that'd be an upcharge.
[Main Desktop]
CPU: AMD Ryzen 5 5600X  GPU: EVGA RTX 3070 Ti (FTW3 Ultra)  MOBO: MSI Gaming Pro Carbon (X470)  RAM: G.SKILL Ripjaws V DDR4-3600 CL16 (2x8GB)
COOLER: Arctic LiquidFreezer II 280 STORAGE: G.SKILL Phoenix FTL 240GB SSD, Crucial MX500 1TB SSD, Toshiba 2TB HDD, Seagate 4TB HDD
PSU: EVGA GQ-1000W 80+ Gold  CASE: The MESHMOD v1.0 (Custom Deepcool Matrexx 70 chassis)  MONITOR: AOC 24G2 144Hz (IPS)
MOUSE: Logitech G502 HERO (wired)  KEYBOARD: Rosewill K81 RGB (Kailh Brown)  HEADPHONES: HiFiMan Ananda, Drop x Sennheiser HD6XX
IEMS: 7Hz Timeless, Tin Audio T2, Blon BL-03, Samsung/AKG Galaxy Buds Pro  STUDIO MONITORS: Mackie MR524, Mackie MRS10  MIC: NEAT Worker Bee
INTERFACE: Focusrite Scarlett Solo  AMPLIFIER: SMSL SP200 THX AAA-888, XDUOO XD-05 Basic  DAC: SMSL Sanskrit 10th MKII (upgraded AK4493 Version)
WHEEL: Logitech G29 + Logitech G Shifter
[Stream Encoder]
CPU: AMD FX-9590  GPU: Sapphire R9 390X (Tri-X OC)  MOBO: ASUS Sabertooth R2.0 (AM3+)  RAM: G.SKILL Ripjaws X DDR3-1866 (2x8GB)
COOLER: EVGA CLC 280 PSU: MSI A750GF 80+ Gold CASE: Phanteks P400A Digital
[Garage]
CAR: 2003 Honda Civic Coupe LX (EM2)  ENGINE: D17A1, planned K20A2 swap  INTAKE: DIY Solutions Short RAM  HEADERS: Motor1 4-2-1 with Cat-Delete
EXHAUST: Yonaka 2.5" Cat-Back with 3.5" tip (YMCB-CIV0105)  COILOVERS: MaXpeedingrods adjustable  RIMS: Core Racing Concept Seven Alloys (15x6.5)
RECEIVER: Kenwood DPX304MBT  SOUND DEADENING: Damplifier Pro Deadening Mats  SOUND DAMPENING: Custom solution, layers of thick insulation
DOOR SPEAKERS: Kenwood KFC-P710PS 6.5" Components  WINDOW LEDGE SPEAKERS: Kenwood KFC-6996PS 6x9" 5-Ways
https://linustechtips.com/topic/1342817-sim-graphics-help/#findComment-14768708
Thanks for letting me know. Is there an actual end in sight for this chip shortage?
https://linustechtips.com/topic/1342817-sim-graphics-help/#findComment-14769686
I’ve heard the end of the year minimum for some stuff.
https://linustechtips.com/topic/1342817-sim-graphics-help/#findComment-14769918
