I7 920 CPU, Asus PT6 mobo, what GPU and Monitor?
Solved by LIGISTX,
8 minutes ago, JohnVee said:Just wonder what would be a good GPU (and monitor) fit for my old system from 2009:
Intel I7 920 cpu
Asus P6T mobo
Needs a new Monitor and GPU.
Thanks.
I still have my 920 and P6T deluxe V2! Lol. Such a monster for the time. I think I ended up with a gtx 275 in mine before I retired that system. Or, hmm, maybe a gtx 470, that sounds more right.
If you can get like a gtx 970 for a good price, that would be a pretty solid option.
If you can, OC the CPU as much as possible. I ran mine 3.86 ghz 24/7 for years. 21 multiplier (you can lock it at the turbo multiplier which is 21), and decent cooling and you’d be pretty solid!
