Urgent: CPU came out with the Cooler. And is stuck on the cooler.
Solved by Beerzerker,
Acetone can make it loosen up.
I'd suggest using a simple flathead screwdriver on one side, just insert the tip between the chip and cooler, then gently give the driver a twist, holding this pressure steady to it, don't try to actually force it loose.
You may have to hold this pressure for a little while but eventually it will give. Beware of it suddenly flipping off the cooler, "Feel" what's happening with the chip and once you start to feel a change, back off the twisting pressure because that means the bond has been broken and you should be able to complete the process more easily. You can lay your hand over the chip while doing it to control this so it doesn't fly off the cooler and have bent pins when it lands.
