7 minutes ago, Tech87 said:
If it's argb, then the cooler will have a little 3 pin plug you have to plug into your motherboard.
Whats the make/model of the cooler?
Nevermind it is DEEPCOOL GAMMAXX GT BK, CPU Air Cooler, SYNC RGB Fan and RGB Black Top Cover, Cable or Motherboard Control Supported, 4 Heatpipes, 120mm RGB Fan, Universal Socket Solution
https://linustechtips.com/topic/1341335-cpu-color/#findComment-14757516
Okay, that cooler appears to be regular RGB rather than ARGB.
It should come with a controller that you can use to control the lighting, or you can plug the 4 pin plug directly into the 12v RGB header on your mobo, and control it through the lighting software of your motherboard brand (Asus aura sync, MSI mystic light, etc)
PSU Tier List   AMD Mobo Tier List   SSD Tier List
If your issue is resolved, please share the fix with the community.
https://linustechtips.com/topic/1341335-cpu-color/#findComment-14757525
i do not have any sort of controller
https://linustechtips.com/topic/1341335-cpu-color/#findComment-14757537
Hmm did you buy it used?
It should come with a controller that is powered by sata.
If new, double check your packaging.
If you still can't find it, then locate a 4 pin 12v RGB header on your motherboard and plug the 4 pin female connector into it.
https://linustechtips.com/topic/1341335-cpu-color/#findComment-14757544
Hello VFern,
As @Tech87 mentioned, the Gammaxx GT models should come with an inline RGB controller; unless you have the GTE model that does not come with a controller. You would need to wire it to the 4pin RGB header on your motherboard (you can also do this with the GT model). If you need more in depth assistance, you can submit a support ticket at http://www.deepcool.com/support/index_ticket.shtml
DeepCool Support
https://linustechtips.com/topic/1341335-cpu-color/#findComment-14758995
17 hours ago, Vfern said:
cpu color
I read the name of this thread and got confused, thank god someone isn't trying to color their CPU, I would've been disappointed 👀
What would that even look like? A spray-painted IHS? That's gotta be bad for thermal conductivity 😆
[Main Desktop]
CPU: AMD Ryzen 5 5600X  GPU: EVGA RTX 3070 Ti (FTW3 Ultra)  MOBO: MSI Gaming Pro Carbon (X470)  RAM: G.SKILL Ripjaws V DDR4-3600 CL16 (2x8GB)
COOLER: Arctic LiquidFreezer II 280 STORAGE: G.SKILL Phoenix FTL 240GB SSD, Crucial MX500 1TB SSD, Toshiba 2TB HDD, Seagate 4TB HDD
PSU: EVGA GQ-1000W 80+ Gold  CASE: The MESHMOD v1.0 (Custom Deepcool Matrexx 70 chassis)  MONITOR: AOC 24G2 144Hz (IPS)
MOUSE: Logitech G502 HERO (wired)  KEYBOARD: Rosewill K81 RGB (Kailh Brown)  HEADPHONES: HiFiMan Ananda, Drop x Sennheiser HD6XX
IEMS: 7Hz Timeless, Tin Audio T2, Blon BL-03, Samsung/AKG Galaxy Buds Pro  STUDIO MONITORS: Mackie MR524, Mackie MRS10  MIC: NEAT Worker Bee
INTERFACE: Focusrite Scarlett Solo  AMPLIFIER: SMSL SP200 THX AAA-888, XDUOO XD-05 Basic  DAC: SMSL Sanskrit 10th MKII (upgraded AK4493 Version)
WHEEL: Logitech G29 + Logitech G Shifter
[Stream Encoder]
CPU: AMD FX-9590  GPU: Sapphire R9 390X (Tri-X OC)  MOBO: ASUS Sabertooth R2.0 (AM3+)  RAM: G.SKILL Ripjaws X DDR3-1866 (2x8GB)
COOLER: EVGA CLC 280 PSU: MSI A750GF 80+ Gold CASE: Phanteks P400A Digital
[Garage]
CAR: 2003 Honda Civic Coupe LX (EM2)  ENGINE: D17A1, planned K20A2 swap  INTAKE: DIY Solutions Short RAM  HEADERS: Motor1 4-2-1 with Cat-Delete
EXHAUST: Yonaka 2.5" Cat-Back with 3.5" tip (YMCB-CIV0105)  COILOVERS: MaXpeedingrods adjustable  RIMS: Core Racing Concept Seven Alloys (15x6.5)
RECEIVER: Kenwood DPX304MBT  SOUND DEADENING: Damplifier Pro Deadening Mats  SOUND DAMPENING: Custom solution, layers of thick insulation
DOOR SPEAKERS: Kenwood KFC-P710PS 6.5" Components  WINDOW LEDGE SPEAKERS: Kenwood KFC-6996PS 6x9" 5-Ways
https://linustechtips.com/topic/1341335-cpu-color/#findComment-14759142
