Possible dead 3070
Go to solution Solved by Mark Kaine,
22 minutes ago, IkeaGnome said:
It's a KF. It won't have iGPU.
@SecretduckyAs a last ditch effort, if you haven't already try different video cables and different ports.
I would also try the GPU in another computer… i know it looks like dead memory, but still something about this all is a bit odd, Id definitely want to know before sending a possibly working RTX 3070 back, personally .
Just got my cyberpower custom build today, i9-11900kf, 32gb ballistics 3000mz ram, aorus 3070, thermaltake 750w 80+ gold
and in bios its just a artifacting mess, gouz shows memory size, memory clock, and gpu clock all at 0, nvidis control panel will not open, and sait that it wasn't connected to a nvivda gpu(it is), is the gpu dead? Been trying to troubleshoot for 4 hours now. Bios update, driver updates, boot in safe mode, nothing works. Ill attach some photos of gpuz and my bios screen
https://linustechtips.com/topic/1340413-possible-dead-3070/
looks dead
Main Rig:
Ryzen 5800x, ASUS Crosshair Hero VII Wi-Fi, 32gb of Corsair Vengence Pro SL 3600 CL18, Sapphire Pulse 9060xt 16gb, Noctua NH-D15 LTT Edition, Soundblaster AE-7, Beyerdynamic DT 990 Edition 600 Ohm headphones, 1tb ADATA SX8200 NVME SSD, 1tb Intel 665P NVME SSD, 500gb Samsung 850 EVO SATA SSD, 8tb WB Black SATA HDD, 14tb WD Ultrastar HC530, LG SATA Blue Ray Drive, EVGA 1300w G+ PSU, Coolermaster Stryker case, ROG ARGB strips, China ARGB fans.
HTPC:
Ryzen 5800xt, ASUS B550M Prime Plus WiFi II, 32GB of Corsair LPX 3200 CL16, ASUS 5060 8gb LP, Noctua L9-x65 cooler, WD Black SN770 500gb NVME SSD, WD Black SN770 1tb NVME SSD, Crucial MX500 2tb SATA SSD, WD Blue 2tb SATA HDD, Pioneer Blu-Ray burner, Intel AX200 WiFi/Bluetooth, Seasonic 300w TFX PSU, Silverstone ML11 case.
Retro Gamer PC:
VIA C3 1000Mhz, VIA Epia PD-10000 LVDS, 1gb of Kingston DDR, PNY Geforce FX5500 128mb PCI, WD 80GB HDD, Random CD-ROM, Random 250w mini psu, Mini ITX case 🤣
https://linustechtips.com/topic/1340413-possible-dead-3070/#findComment-14751352
If you're seeing lines/graphical issues in the BIOS as well, then the graphics card is defective (most likely related to VRAM).
CPU Cooler Tier List  || Motherboard VRMs Tier List || Motherboard Beep & POST Codes || Graphics Card Tier List || PSU Tier List
Main System Specifications:
CPU: AMD Ryzen 9 5950X ||  CPU Cooler: Noctua NH-D15 Air Cooler ||  RAM: Corsair Vengeance LPX 32GB(4x8GB) DDR4-3600 CL18  ||  Mobo: ASUS ROG Crosshair VIII Dark Hero X570  ||  SSD: Samsung 970 EVO 1TB M.2-2280 Boot Drive/Some Games)  ||  HDD: 2X Western Digital Caviar Blue 1TB(Game Drive)  ||  GPU: ASUS TUF Gaming RX 6900XT  ||  PSU: EVGA P2 1600W  ||  Case: Corsair 5000D Airflow  ||  Mouse: Logitech G502 Hero SE RGB  ||  Keyboard: Logitech G513 Carbon RGB with GX Blue Clicky Switches  ||  Mouse Pad: MAINGEAR ASSIST XL ||  Monitor: ASUS TUF Gaming VG34VQL1B 34"
https://linustechtips.com/topic/1340413-possible-dead-3070/#findComment-14752608
8 hours ago, PhilAstisxh said:
that hurts...
Just calling it how I see it. It does suck. I was so scared of getting a defective card when my 3060 came in last week.
Main Rig:
HTPC:
Retro Gamer PC:
https://linustechtips.com/topic/1340413-possible-dead-3070/#findComment-14752611
16 hours ago, Secretducky said:
Crazy to me, how can this pass a quality control? I paid for overclocking too, like you would think someone saw that bios screen, or that the gpu has 0 memory, idk still so pissed about the whole thing
Things happen. Possible it could have happened in shipping.
Main Rig:
HTPC:
Retro Gamer PC:
https://linustechtips.com/topic/1340413-possible-dead-3070/#findComment-14752615
Tbf you bought a prebuilt those are typically shipped "pre built" and that isnt something PC parts are designed for at all, so there is a big, inherent risk in doing so.
You are a brave man or woman.
My advice is RMA the whole PC if possible , and dont let them overclock anything because who knows what they're doing.
-Scott Manley, 2021
https://linustechtips.com/topic/1340413-possible-dead-3070/#findComment-14752624
I got prebuilt becuase its one of the only reliable ways to get a gpu, would love to build my own but cant justify 1200 for a gpu, my reason for bringing up overclocking, which was only 10% but still oc, was that someone would have had to go into bios, and if they had they would have seen the artifacting, iv calmed down a bit since posting this and understand that it would possibly be from shipping. Also would rather not rma whole pc, just gpu, but if i have to i have to 🤷‍♂️
https://linustechtips.com/topic/1340413-possible-dead-3070/#findComment-14752745
Ok, actually it would be probably better to just exchange the GPU, that way if the new GPU doesnt work properly either you would kinda know its the motherboard most likely. Either way is not ideal but i see why that would be preferable.
Did you try the PC without the GPU, does it work normally? It has an iGPU, right?
-Scott Manley, 2021
https://linustechtips.com/topic/1340413-possible-dead-3070/#findComment-14752752
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
https://linustechtips.com/topic/1340413-possible-dead-3070/#findComment-14752766
-Scott Manley, 2021
https://linustechtips.com/topic/1340413-possible-dead-3070/#findComment-14752794
I have tried the other pcie slot, same problem, dug a bit deeper and saw error 43 on gpu, seems dead memeory, still waiting on cppc support to email back, thanks for the input, helped a ton
https://linustechtips.com/topic/1340413-possible-dead-3070/#findComment-14752915
