Help with networking layout and access points
Hello, sorry for late reply, had no time during weekend.
On 5/21/2021 at 3:45 PM, Quickstrike said:What's your budget here?
Is the house's electricity on a single box?
Are the wall studs made from wood or aluminum?
Are the exterior walls covered in aluminum clapboard?
Will the WIFI be integrated for both floors?
1. Let's say the budget is set in terms of best value per $. As I have no experience, according to my research, I was thinking about 1000$ at max, but I don't have a clue, if it's fitting or not.
2. Why this matters? There is single box in the house.
3. There are no wall studs. It's just plain brick and cement building. Whole house is build like a fortress, every inch of electrical wiring has to be drilled into the walls directly.
4. Also there are no clapboards. The outside walls are made from 30cm thick brick (just google Porotherm 30) and on the outside part there is approx 15cm-20cm thick polystyrene and on it the facade paint.
For point 3 and 4 I am actually quite unsure about my answers as I am not builder, so I am using a lot of googling as I hit the language barrier in this field.
5. Wifi needs to be integrated and strong for both floors, yes.
On 5/21/2021 at 3:46 PM, Quickstrike said:And how many and what type of users?
Also, how much streaming and at what resolution
6. Not sure how to understand this question. Wife and I will be working from home usually whole week so 2 laptops, my personal PC (which will be most probably connected by ethernet cable) and a lot of phones (each household member have at least one phone - so 6x phones for sure). Then other additional devices, e.g. android box, wireless printer, smart TV of parents. During normal day (from 7am to 16:00), most of the network needs will have to be prioritized for me and wife (let's say 80% for us).
7. Not too much streaming, most of the devices are FullHD, TV will be in 1year+ switched to 4K, mainly used for Netflix.
Hopefully these are correct answers you are looking for. In any case, feel free to challenge me or my answers and I will try to reply as soon as possible.
Thanks mate!
