Hello world,
my friend's macbook pro's display stopped outputting a signal. Even when plugged in, the only sign of life is the green indicator LED on the keyboard...
What could be causing this?
It is pretty urgent cos he has everything on it. Any help is appreciated!
(I have conducted countless disassemblies on pcs, laptops, even phones but this is my first macbook)
Thank you so much
e.
https://linustechtips.com/topic/1339976-2017-mb-pro-no-display/
Tried a reboot and NVRAM/SMC reset? Can it output to an external display?
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
https://linustechtips.com/topic/1339976-2017-mb-pro-no-display/#findComment-14747925
It can output to a external display
I have a suspision that it might be a loose connector since he carries the laptop a lot and throws the bag around but Im not sure
what is a NVRAM / SMC reset and how do I do it?
just some side info, the battery is in poor condition
https://linustechtips.com/topic/1339976-2017-mb-pro-no-display/#findComment-14747945
Resetting the SMC: https://support.apple.com/en-us/HT201295
Resetting NVRAM: https://support.apple.com/en-us/HT204063
There aren't many connectors to come loose inside Macs, but it could be worth opening it up to check the display connector if you have the appropriate pentalobe bits (they're not torx, it's 5 points vs 6).
If it can currently output to an external display though, I'd be sure to back it up ASAP so if it gets worse he'll still have all his stuff. Recommend doing a SuperDuper clone. If you're running Big Sur, apparently the beta in the latest post here works for it: https://www.shirt-pocket.com/blog/. Otherwise you download an older version as per here, and just clone the data apfs container, which you can import to any mac during the setup process, or browse through and manually move stuff.
Mouse: EVGA X17
https://linustechtips.com/topic/1339976-2017-mb-pro-no-display/#findComment-14747971
