the mounting system for sWRX8 is identical to TR4, sTRX4, and SP3, so noctua's TR4-SP3 coolers are a go, and a custom loop originally for normal threadripper might be possible
https://noctua.at/en/can-noctua-tr4-sp3-coolers-be-used-on-the-swrx8-socket
Fuck you scalpers, fuck you scammers, fuck all of you jerks that charge way too much to tech-illiterate people.
Unless I say I am speaking from experience or can confirm my expertise, assume it is an educated guess.
Current setup: Ryzen 5 3600, MSI MPG B550, 2x8GB DDR4-3200, RX 5600 XT (+120 core, +320 Mem), 1TB WD SN550, 1TB Team MP33, 2TB Seagate Barracuda Compute, 500GB Samsung 860 Evo, Corsair 4000D Airflow, 650W 80+ Gold. Razer peripherals.
Also have a Alienware Alpha R1: i3-4170T, GTX 860M (≈ a 750 Ti). 2x4GB DDR3L-1600, Crucial MX500
My past and current projects: VR Flight Sim: https://pcpartpicker.com/user/nathanpete/saved/#view=dG38Jx (Done!)
A do it all server for educational use: https://pcpartpicker.com/user/nathanpete/saved/#view=vmmNcf (Cancelled)
Replacement of my friend's PC nicknamed Donkey, going from 2nd gen i5 to Zen+ R5: https://pcpartpicker.com/user/nathanpete/saved/#view=WmsW4D (Done!)
https://linustechtips.com/topic/1339955-swrx8-cooling-options/#findComment-14747752
It's identical to the options already out there for threadripper. One just needs to make sure the rotation does not effect the case it's being installed in.
The only cooler that would run into problems is the Ice Giant unless building bench style/horizontal.
It'd be better to discuss what you're looking to do to get some specific answers.
https://linustechtips.com/topic/1339955-swrx8-cooling-options/#findComment-14747753
I plan on building a editing rig for a friend who produces short films.
And as I couldn't find the info on coolers (water or air) I thought it was better too ask than to buy parts
that maybe didn't fit or wrok correctly.
https://linustechtips.com/topic/1339955-swrx8-cooling-options/#findComment-14749423
Ok, so if it's for someone else, then you definitely should NOT go custom loop. If something goes wrong, you don't want to have to be tech support for it.
I would go for the Noctua U14S or the Cooler Master ML360 TR4. I've used both and bother were reliable.
https://amazon.com/Cooler-Master-MasterLiquid-Close-Loop-Threadripper/dp/B08W2JL94D/r
https://linustechtips.com/topic/1339955-swrx8-cooling-options/#findComment-14749458
