Help, pc wont start!
Go to solution Solved by crisisweird25,
Okay sooo I may or may not have forgotten to update everyone on this, so It was the motherboard and I decided to get the Asus B365M pro 4 as it was compatible with everything I have in my build. it is now up and running and i have been loving it so far! thanks to you lot for helping me out on this!
So this is my first pc build and after getting everything hooked up, it wont start. I found out that the front pannel wasnt actually connected with f pannel connections but other than that i have no clue what is wrong with it. Any help would greatly be appreciated thanks!
I keep thinking its the psu and that i forgot to plug in something. What does Perif 1 mean / stand for?
https://linustechtips.com/topic/1339430-help-pc-wont-start/
You really should give your full spec on this.
Are you sure that PSU switch is on? Is every cable clicked shut?
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
https://linustechtips.com/topic/1339430-help-pc-wont-start/#findComment-14743623
Right right I gothca (I typed this out first but I accidently closed it out on mobile so i took a screenshot instead) Edited: forgot to add my Gpu. Its a gifted MSI 1060 6gb mini
Yeah the switch is on and most of the connections are plugged in all the way but I can double check in the morning
https://linustechtips.com/topic/1339430-help-pc-wont-start/#findComment-14743654
your build list has very odd choices that really do not make any sense at all.
anyway is the front panel connectors connected now? When you press the start button nothing happens? that indictaes that the fornt panel connectors are not in or the psu is not on.
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
https://linustechtips.com/topic/1339430-help-pc-wont-start/#findComment-14743664
7 hours ago, ndesign.ie said:
remove the front panel connections, use a screwdriver to short the power on pins
If that doesnt work, faulty board
Ok so i did this annddd...nothing, looks like its a faulty board like you said, im gonna look into a new board and check out if i have the right power supply and that it supplys power to everything. Otherwise thank you all for your help!
https://linustechtips.com/topic/1339430-help-pc-wont-start/#findComment-14745427
  • 1 month later...
https://linustechtips.com/topic/1339430-help-pc-wont-start/#findComment-14821806
