I have a total of 6 fans on my h500m, 3 on top(radiator) (inward), 2 at the front(inward), 1 at the back(outward). Currently my radiator is inside of the case while all the 3 fans are outside of the case pulling air into the case. I want to have all the fans inside my case and radiator outside the case. Should i change the airflow or just keep the current airflow direction which is inward.
Oh btw im using corsair h150i pro
< ̄`ヽ、       /  ̄ >
 ゝ、  \ /⌒ヽ,ノ   /´
   ゝ、 ( ( ͡◉ ͜> ͡◉) /
     >     ,ノ
sorry for my bat englandski
https://linustechtips.com/topic/1339383-top-radiator-configuration/
Using the top for exhaust seems more balanced and would probably cool the graphics card better but the cpu worse. The graphics card is usually more sensitive to temps so I'd prioritize that.
I'll try that and see how it goes especially the cpu temp
< ̄`ヽ、       /  ̄ >
 ゝ、  \ /⌒ヽ,ノ   /´
   ゝ、 ( ( ͡◉ ͜> ͡◉) /
     >     ,ノ
