https://www.amd.com/en/products/cpu/amd-ryzen-5-2500x
so the cpu in my pc supports 2933hz ram but i cannot find anywhere that shows the mobo can, is there a way i can know cause i don't want to buy the ram and realise that it will not run at 2933hz speed, cpu id and HWiNFO  do not show it
https://linustechtips.com/topic/1339283-mobo-ram-speed/
Then you look it up on the site of the board, don't stay on the CPU's page
Desktop benching:
https://linustechtips.com/topic/1339283-mobo-ram-speed/#findComment-14742390
The MOTHERBOARD is what directly controls what speed the RAM runs at, not the CPU; that just sets the maximum speed.
**I frequently edit any posts you may quote; please check for anything I 'may' have amended.**
Current PC spec. in my profile.
Can I realistically call myself a gamer, if I only play ONE, twenty year old game...?
Did you test boot it, before you built in into the case?
WHY NOT...?!
https://linustechtips.com/topic/1339283-mobo-ram-speed/#findComment-14742399
Just now, freddiecraven said:
Cannot find a page for the mobo cause it was from a pre build not unless it’s an obscure website 4000 pages in google
then look up the chipset you have. This is something software like HWinfo or CPU-Z can tell you.
Desktop benching:
https://linustechtips.com/topic/1339283-mobo-ram-speed/#findComment-14743099
What make/model is the pre-build?  If it's a boutique pre-build, they should use off-the-shelf Motherboards.
If you can get into the BIOS, it should be shown there.
WHY NOT...?!
https://linustechtips.com/topic/1339283-mobo-ram-speed/#findComment-14744316
