I'm looking to build an RTX 3060 Ti  Ryzen 7 3700X PC, but I'm not sure what I should do for the PSU. I was thinking 650 watts, but is that overkill? Just about every PSU I look at on Amazon have these horror stories as top reviews, so it's driving me away from nearly every PSU. I'm on a budget so I don't need anything too fancy, 80+ Bronze Semi-Modular is ideal. I appreciate any help!
https://linustechtips.com/topic/1339274-need-help-selecting-a-psu/
I Have a Corsair RM650x Fully modular 80+ gold unit and I have had no issues. Cost me 112$ and my only complaint is the cables are a little stiff.
Gets my seal of (IT DOESN'T EXPLODE)
Others will recommend other things and this might be out of your price bracket but it's what I have and it works fine 🙂
| If someones post is helpful or solves your problem please mark it as a solution 🙂 |
I am a human that makes mistakes! If I'm wrong please correct me and tell me where I made the mistake. I try my best to be helpful.
System Specs
<Ryzen 5 3600 3.5-4.2Ghz> <Noctua NH-U12S chromax.Black> <ZOTAC RTX 2070 SUPER 8GB> <16gb 3200Mhz Crucial CL16> <DarkFlash DLM21 Mesh> <650w Corsair RMx 2018 80+ Gold> <Samsung 970 EVO 500gb NVMe> <WD blue 500gb SSD> <MSI MAG b550m Mortar> <5 Noctua P12 case fans>
Peripherals
<Lepow Portable Monitor + AOC 144hz 1080p monitor>
<Keymove Snowfox 61m>
<Razer Mini>
budget?
geometry is hard
b550 > x570
