So now im planning to upgrade my CPU and motherboard, and I plan to OC it so I will need a CPU cooler. Because my budget is limited I can only get at most 70$ for cpu cooler, which bring me to the choice of the Seidon 120v. So I want to ask is it a good one or should I go for smt else like the H60? Or water cooler at this price is not good at all and I should use the Hyper 212 evo/plus instead?
My rig: Intel Core i7 4790k | MSI Z97 PC Mate | GSKILL Ripjaws X 16GB 1866MHz | ADATA Premier SP550 480GB SSD | Seagate Barracuda 3TB | Seagate Barracuda 2TB  | MSI Gaming X GTX 1070 | Thermaltake Versa N21 | Corsair CX550M Semi Modular PSU | AOC G2460PF 144Hz | Logitech G502 | GSKILL Ripjaws KM780  | GAMDIAS HEPHAESTUS V2  PCPartPicker | Old Build Log | New Build Log
https://linustechtips.com/topic/133894-choosing-a-cpu-cooler/
Ryzen 1600@3.8ghz / 16gb 2400mhzASRock B350 ITX / Gigabyte RX 470 4gb / 256gb M.2 / SG13B-Q / Corsair 450w
https://linustechtips.com/topic/133894-choosing-a-cpu-cooler/#findComment-1781768
The Seidon 120v doesn't perform all that well for its price, I would recommend the Phanteks 140 beast(forgot the number), it's on sale for $74.99 on newegg
[AMD Athlon 64 Mobile 4000+ Socket 754 | Gigabyte GA-K8NS Pro nForce3 | OCZ 2GB DDR PC3200 | Sapphire HD 3850 512MB AGP | 850 Evo | Seasonic 430W | Win XP/10]
https://linustechtips.com/topic/133894-choosing-a-cpu-cooler/#findComment-1781780
I forgot to mention that my case is the cougar archon black, I cant really get a big radiator like h100i. So I shouls use air cooler after all?
https://linustechtips.com/topic/133894-choosing-a-cpu-cooler/#findComment-1781788
