ARGB controller confusion
Go to solution Solved by thrasher_565,
10 hours ago, LaNiz said:
I honestly don't see it.
In downloads section, there is the manual and product sheet pdf.
oh my bad
https://masterplus.coolermaster.com/
Long story short, I want to upgrade a old pc with some RGB. The motherboard has no RGB headers on it.
Then I saw this controller MFP-ACBN-NNUNN-R1. It's a cooler master argb hub. It's bigger than the argb small controller.
This controller, MFP-ACBN-NNUNN-R1, is not listed as being compatible with masterplus+ software.
Is this a mistake, does MFP-ACBN-NNUNN-R1 controller not work with masterplus+? This has me very confused. It looks like a better small argb controller, but somehow not supported by masterplus.
Seeing all this after I have bought a masterbox TD500 mesh argb. Will be adding 4 more argb fans (cm SF argb). Is my project dead now? Or the controller works, was mistakenly not listed?
Thank you for any help.
Link to MFP-ACBN-NNUNN-R1 https://www.coolermaster.com/catalog/coolers/rgb-accessories/argb-led-controller/#item1
Link to small argb controller https://www.coolermaster.com/catalog/coolers/rgb-accessories/argb-led-small-controller/#item1
Masterplus compatibility list https://masterplus.coolermaster.com/
Apologies for typos/grammar.
https://linustechtips.com/topic/1338005-argb-controller-confusion/
6 hours ago, LaNiz said:
Am sorry I don't see how that helps.
You linked to the controller that I want to get.
Will it work with masterplus software?
there's a link on the page to download its software.
oh my bad
