Posted May 13, 2021 Is it possible to add an airflow filter to a Phantom Eclipe P360A?(or any case) https://uk.pcpartpicker.com/list/4sV74s Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 14, 2021 3 hours ago, noodlespinbot said: Is it possible to add an airflow filter to a Phantom Eclipe P360A?(or any case) what you mean airflow filter? dust filter you can add to any fan. I have dyslexia plz be kind to me. dont like my post dont read it or respond thx also i edit post alot because you no why... Thrasher_565 hub links build logs Corsair Lian Li Bykski Barrow thermaltake nzxt aquacomputer 5v argb pin out guide + argb info 5v device to 12v mb header Odds and Sods Argb Rgb Links Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 14, 2021 Author 13 hours ago, thrasher_565 said: what you mean airflow filter? dust filter you can add to any fan. ohhhhhhhhhh ok thanks. i guessed that but the case review worded it different. Thanks for the response! https://uk.pcpartpicker.com/list/4sV74s Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 14, 2021 19 hours ago, noodlespinbot said: Is it possible to add an airflow filter to a Phantom Eclipe P360A?(or any case) I bought the Tecware Forge M it's front is like the meshify c mini without the dust filter, I DIY a dust filter for the front with a cooler's carbon filter for $2.00 I'm sure theP360A can be done too. Look to the left, slap from the right, look to the right, slap from the left, look up, kick down low, look down low, uppercut to the head. Congrats I've been knocked out. Spoiler CoolerMaster NR400, Ryzen 7 5800x, Asus TUF gaming b550m plus WiFi, Scythe Fuma 2, Corsair Vengeance Pro Rgb 3200mhz 16gb cl16 (8gb x 2),Asus ROG Strix gaming Vega 56 12gb,Crucial P1 nvme 1tb m.2 ssd, Crucial Mx 500 2tb sata ssd x 2, Seasonic Focus Plus 750w 80+ Gold. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
