My GeForce GTX 1080 Ti bit the dust. Need a replacement ASAP!
Brony
Hey all. My GPU just died and I need a replacement for it. It was a Gigabyte GeForce GTX 1080 Ti. I've been looking at RTX 3080 but it's unavailable everywhere. I use it for gaming on a 1440p resolution with the highest fps I can play at. I don't use it for anything else. Budget is $1200.00 thank you all!
Yeah unless you are willing to go and buy something that is probably less powerful than your 1080 Ti you are definitely shit out of luck brother.
